Best Quality Spacers!?
Ve 8
Saudi Arabia
Dark Horse
What is the best quality 25mm spacers’ brand for the Dark Horse? I have ZERO experience with spacers
Why do you want that much offset? There are downsides to spacers that get worse the wider they are.
A.alansari
Qatar
Mustang GT 2024 PP
This is the minimum that will fit without cutting or changing the studs
I have been using steeda spacers for almost a year without problems but you will need rock guards or else you will chip the paint
The reason I avoid spacers is because they shift the load path on the wheel bearings, and disrupt steering geometry to a greater or lesser degree.
Unless they are used to correct a wrong offset in a wheel.
Suvak [BANNED SCAMMER]
United States
2016 Ford Mustang
I don’t have personal experience with spacers, but most Mustang owners recommend going with hub-centric brands like Eibach or Steeda. They fit the S650/Dark Horse well, and the 25mm size is commonly used without issues.
