AOOA brake caliper covers installed
South Carolina
I have the spacer for a better wheel offset with the 8.5” nite ponies. The covers are supposed to fit but I have not actually tried it without the spacers.
I will say that AOOA chat support was helpful in ensuring the fit. They asked me to send pictures of my calipers and told me what the necessary clearance was I needed. You may wanna go on the website and reach out to them directly.
I have a different set of wheels, next time I swap them out I will check and post back here.
89Trooper
Central Florida
Not the sharpest picture, but the sun was low and lighting up the covers. Unless you knew the real rear Brembos should be on the front side, you’d never know.
S650 Mustang AOOA brake caliper covers installed IMG_8194
steve_2020Eco
2020 Mustang
One done!
Takes longer to make sure the Brembo sticker is centered and straight than it does to install. Lol.
Excellent quality and perfect fitment!
How do these attach to the calipers? Solid fit? How long did it take to install them?
sunnydhama
sunnydhama
Ford Mustang Ecoboost '24 race red; active exhaust
Yeah its solid fit, time required is jacking up car + taking tires off plus 10 mins to fit and tight them on all 4 corners
steve_2020Eco
2020 Mustang
Now, I just need to decide what color…
my wheels
S650 Mustang AOOA brake caliper covers installed IMG_9974
Probably will go with red,
S650 Mustang AOOA brake caliper covers installed IMG_9970
but blue or white might be cool as well
S650 Mustang AOOA brake caliper covers installed IMG_9969
S650 Mustang AOOA brake caliper covers installed IMG_9971
brownbear313
winsted CT
2020 mustang GT
Just a really important piece of advice Uncle really helped me a lot, but unfortunately, nobody was able to get a clear answer. You can run any cover on the rear without clearance issues. If you ask Aooa about the front, they say it will fit no issues, but there are many issues. I had a set of spacers laying around just in case and they 100% would not clear, and I don’t even have the Brembo 6pistons. Personally, I hate spacers and I always noticed a difference in Road vibration so I ended up painting my front brakes.
S650 Mustang AOOA brake caliper covers installed IMG_6408
2ndTryPony
usa
2024 S650 GT
sorry to revive old thread but I’m looking to add these covers and I have the same wheels you have. Did you have to add any spacers to the front wheels to clear the covers? I installed one cover and the space between the wheel and cover is maybe 1/8”. Feels like it shouldn’t be that close.
S650 Mustang AOOA brake caliper covers installed IMG_1433
S650 Mustang AOOA brake caliper covers installed IMG_1432
D/\rK•650
2025 Mustang DarkHorse
Is it actually hitting the rim? Because it looks like it in the bottom pic
2ndTryPony
usa
2024 S650 GT
It’s very close to hitting it. I’m thinking of doing some 1/4” (6mm) spacers but not sure if I should do maybe 8mm? Don’t want to have I modify anything on the wheels besides adding the small spacers.
D/\rK•650
Yeah im not sure I would put spacers on just for the caliper covers but thats just me. If you want to I would get thinest as possible as to not change the width to much. Unless your wanting to get a bit wider ect.
brownbear313
winsted CT
2020 mustang GT
Spacers needed for even non PP I ended up painting my fronts after installing and running spacers
