thornclaw
northbrook, il
2015 mustang gt
if you have the wireless charger and it just heats up your phone instead of charging it , you can replace it fairly cheaply. you have to remove the wireless factory block and replace it with a custom piece made of 3/4 inch plywood. The factory charger pops out easily with a screwdriver and you just unplug it. router out a cutout for a standard wireless charger from amazon. works great. see pics. maybe someone can make a 3d printed version and sell it on the forum.
thorn
S650 Mustang $6 wireless charger fix DIY pic1
S650 Mustang $6 wireless charger fix DIY pic2
S650 Mustang $6 wireless charger fix DIY pic3
S650 Mustang $6 wireless charger fix DIY pic4
S650 Mustang $6 wireless charger fix DIY pic5
Nunya
CA
S650
Good job!
Was there a way to hard wire it? How was the factory unit energized?
Paul's stable
Maple Ridge BC Canada
thorn
Do you think if a person did this would they be able to hook it up to the power from factory charger? So you do not see the power cable. Other than that looks great.
thornclaw
northbrook, il
2015 mustang gt
there is a wiring harness that connects to the factory charger. it would not be easy to hardwire it using that without damaging the harness.
POHLHAMMER
Wisconsin
There has been much debate on whether or not the factory charger works. Several members swear it works great. I am one of the majority who has one that absolutely does not work at all.
Can you cut the OEM charger off after the connection? Then you can see what kind of power is coming through the wires ? This obviously may destroy the OEM charging pad , but I guess that won't matter as its junk anyways.
Do you have a picture of the removed OEM charger ? Does it have a pigtail on it ?
It sure would be nice to use that feature, but even with no case on my Galaxy S26 ultra; it overheats phone within minutes.
Nice fix 👍
Nice fix 👍
Well now, TBF, it does heat up the phone really well, which would help if you live in, say ... ALASKA.
POHLHAMMER
Wisconsin
thornclaw
northbrook, il
2015 mustang gt
erocker
Milwaukee, WI.
Do you know how many wires? I'll take a look myself tomorrow with a multimeter. I'm curious to see how much power is going there.
Mine seems to work but it also gets pretty hot.
Gunnar2015
2026 Mustang GT Premium
I'm in awe when you can do something like this on your own, but I just purchased one and personalized it.
S650 Mustang $6 wireless charger fix DIY Charge pad for 2026
