3.55:1 Limited-slip rear axle option VERSUS 3.55:1 TORSEN Limited-slip rear axle (Performance Package with automatic)
TTown
Tulsa, OK
Previous - '19 GT, '24 ZL1 - Next, '25 GT, DH?
What is the practical difference between these two options?
LETHAL
From the D but in the NC
From the D to NC
Fortnutgamer
USA IL
2022 Mach 1
For street use - none.
If you plan on tracking the car at all, the torsen must be equipped. You will burn through the clutch based one, also lockup will be more unpredictable in my opinion. It will make you less confident when at the limit. The torsen in the mustangs are pretty good.
sdsteele2
Tennessee
24 Mustang GT
In normal driving not much. The normal limited slip uses springs and clutches, the torsen uses an arrangement of biased gears to provide the limited slip
TTown
TTown
Tulsa, OK
So the Torsen won't have much beneficial effect in terms of getting off the line in a 0-60?
as fortnut and sdsteele said, for road use there's almost none. the difference comes with performance driving or even just spirited driving. the regular limited slip has clutch packs that need time to engage and wear out. the Torsen diff uses some worm and spur gears, and engages instantly when needed because of that. unless you are outright abusing and not doing the proper maintenance on it, the Torsen diff will almost always last the lifetime of the vehicle, where the regular diff will eventually need the clutch packs replaced. one shortcoming of the Torsen diff is that if a wheel is slipping and it has near 0 traction, then it can have issues, but AdvanceTrac will help then by applying a brake and now you have torque again. if nothing else, a Torsen diff might be worth it because of the reduced long-term maintenance
