25 Premium 9 Speaker Setting for Best Sound Quality
MarkS650GT10
Kansas
2025 Mustang GT 400A Premium 10 Speed
Just got a new 25 GT Premium 400A with the 9 speaker stereo. wanted to get opinions on what others have set their system up for best sound.
I use spotify free and have the streaming settings set to high quality. have the bass turned up to around 75 percent max, midrange little below middle of range and treble little above the middle of range.
left the fade and balance at middle. set it to optimized for driver. set it to surround sound.
sounds pretty good but if any suggestions on improvements i will give it a try, thanks!
RaceRedder
Houston, TX
Dark Horse HP
My opinion of best setting is very different to others. But my hearing is also affected. I use a lot of trebble.
MarkS650GT10
MarkS650GT10
Kansas
was just reading some older posts about equalizer settings and found one saying to set bass almost all the way up, midrange about 25 percent from lowest and treble around middle (50 percent) anyone tried this? i will give it a try after work.
I also read to set soundstage to the front as rear speakers are terrible, speed compensation to high, use stereo setting, and optimized speakers for all passengers.
MarkS650GT10
MarkS650GT10
Kansas
Have been reading and adjusting settings some more, I switched to using youtube music set to high quality now, much better sound than spotify or pandora free!
adjusted the tone settings, bass around halfway, midrange about 20 percent from bottom, treble about 30 percent from bottom.
kept it set to stereo, optimized for all, speed compensation high.
also just read to not only fade all the way towards front but also fade over the drivers seat if you are driving alone, going to try that after work.
also going to try covering the center speaker with a mouse pad to block that speaker some, see if sounds better that way. read that on mustang6g lots of them unplugged the center speakers or covered it with a drum pad or mouse pad.
