Will these Shelby GT500 wheels fit the 2024 Mustang GT?
kinelisch
ValhallaNitePony
MO
2025 Shadow Black EcoBoost Nite Pony
Bolt pattern is the same, so they will bolt on, and the 20 inch diameter basically guarantees no brake clearance issues, and the widths are less than what others have successfully installed, so yes most likely. I am not sure what their offset/backspacing specs are, which will tell you whether they stick out or if they are tucked in, potentially enough to hang up (unlikely if they were on an S550). If you can get those specs along with your stock specs, this is a great tool to help visualize how they will sit compared to your old setup: https://tiresize.com/wheel-offset-calculator/
They stick out all goofy in the front, Shelby has flared fenders
