V8 Engine cover - how to remove?
Gr8ful
S.Carolina
2023 Santa Cruz, V-Strom 650
I don't want break anything so I am checking with folks that have removed it. Is there a technique or just pull straight up?
Thanks
WhiteMonster
Atlanta
Just pull it. It'll pop out pretty easy if you don't have a strut tower brace on top.
JakeLethal
Wellington, FL
2022 F-150 RCSB 5.0
Thanks
Just give it a good pull and it should pop right off! Just start with one corner and make your way around it if that will help you!
timd38
Hudson WI
Rumor has it you lose about 40 horsepower by removing that plastic piece from the engine bay...
You've been warned!!! LOL
I was told only 22 horsepower loss.
Grabber1
Washington
Do you have to remove the strut tower brace to remove the plastic engine cover ?
JimC
Howell, MI
That's what I found. With the strut tower brace in place there isn't enough room to maneuver it out
Gr8ful
Gr8ful
S.Carolina
Thanks,
there is a noticeable power loss with the cover removed.
NOT
Gr8ful
Gr8ful
S.Carolina
Curb feelers and bumper anti dear devices add 5 hp more for sure.
Gr8ful
Gr8ful
S.Carolina
Well why not the 5.0?
timd38
Hudson WI
If it is like the Eco-Boost, the engine will run cooler with it off.
How do you know since the thermostat controls the temperature? My wife’s Edge Titanium did not come with with an engine cover and I added it and saw zero impact on temperature.
