Tires fitment - 285/35/20 rear and 255/35/20 for the front ?
Rich1967
Coral Springs Florida
Hello everyone I’m trying to put new tires on my S650 will nitto 285/35/20 for the rear fit okay? And 255/35/20 for the front any recommendations thank you
Mr Hyde
florida
2024 mustang GT
Absolutely unless you using a very positive offset thats what im running now. 305 fits fine i think the factory limit is around 325 ish
285s will be no sweat. I assume your intending to swap out all four?
More important is the wheels you'll be using. Are you retaining OEM wheels, or going after market? If you're going AM; wheel width and offset, as noted by Mr. Hyde, will be important to proper fit and operation. You may get a good idea of both by using the Tire Racks online fitment tools (obviously you don't have to buy from them if you so choose) to dial in you preferred wheels and tires. Good luck getting what you want!
Mr Hyde
florida
2024 mustang GT
Wheel SpecsFrontRear
Diameter 20"20"
Width 8.5"10"
Bolt Pattern 5x114.3 mm.5x114.3 mm.
Offset +27 mm.+40 mm.
Backspacing 5.78 in.7.07 in.
Centerbore 70.6 mm.70.6 mm.
Weight27.1 lbs27.67 lbs
Sorry was busy at work didnt get to finish post. Im running the lmr nitto nt555 g2 with the downforce wheel those are the specs.
Upacurb
Up a curb at cars and coffee
S550 here- but my car is 315s out back and 305s up front from the factory- considering the shared architecture you should be more then OK
Rich1967
Rich1967
Thank you for the info
