Steeda x pipe or Ford Performance x pipe
Kaleza
Chicago
2024 ecoboost
So i understand they will make the same sound, the only difference is type of steel they use. And steeda uses better steel, 304 compared to 409. Only reason why im asking is because i have bunch of points i can use for fords x pipe. So the question is does the type of steel matters that much in order to justify paying for x pipe compared to just using points. Thank you
mwbgxp
Fairfax, VA
2009 Pontiac G8 GXP, 2017 Subaru Outback 3.6R, 2025 Dark Horse Premium
Following obtained from a Copilot AI query:
"304 stainless steel offers significantly higher corrosion resistance and greater overall durability, while 409 stainless steel trades that performance for lower cost and better high‑temperature oxidation behavior."
There is more info available if you want to do your own query.
Sig Oris
Western Maine
Dave Ramsey would say use the points
steedazach
Valdosta
S650
