Speedo and shift points adjustment
7GHellboy
Lima, Peru
S650 Mustang
I'm currently running 275/35/19 Fronts and 305/35/19 Rears but I have a set of 305/45/18 drag radials for the rear that I plan on using for the dragstrip. Given the height and circumference difference between the fronts and rears with the drag radials, should any adjustments need to be made to the calibration (speedometer, shift points, etc) to compensate for the different height and circumferences in order to have accurate speedometer readings and correct shift points?
It's a 2024 S650 GT and I have an MPVI3 if needed.
Neggytive
you can use any of the hundred or so online tire size calculators to see how much difference there is in diameter and that will give you a good approximation of how far off your speedo is going to be.
I'd be more concerned about how the ABS and other ADAS systems interpret the difference in wheel speed than the speedo and transmission shift points
S650 Mustang Speedo and shift points adjustment 1755613623641-hu
7GHellboy
7GHellboy
Lima, Peru
S650 Mustang
ABS and other driving aids are not relevant for the drag strip. Traction and stability control issues are "fixed" disabling AdvanceTrac. But i dont want overrevving or misshifting because the car "thinks" its going slower or at lower rpms than it is actually going.
~8% difference between front and rear exceeds maximun tolerances (approx 3%) that can be auto adjusted by the Ecu.
Percys650DH
Covington, LA
Steeda Progressive Lowering Springs.
Looks perfect, no issues with the 305/45 with that drop? I’ve got the Steeda dual rate springs on mine and want to do a 305/45 instead of 305/40 but don’t want them to hit the fender or anything
tj@steeda
2015 Steeda Mustang
7GHellboy
7GHellboy
Lima, Peru
S650 Mustang
So far, zero issues.... I'll be doing further testing this weekend at the strip and I'll let you know if anything happens.... bit this combo hooks!!!
Percys650DH
Covington, LA
Good to know! I bet it does, Would love an update after testing
7GHellboy
7GHellboy
Lima, Peru
S650 Mustang
Here's the update: zero issues with this setup, everything works perfect. Even the speedo and shift points are fine after the Lund Tune!!!...
S650 Mustang Speedo and shift points adjustment 1000270445
KarKy
Québec
Ford & Toyota.
Hi! Im looking to add some drag wheel n tires to my performance package too!
What are the specs of your wheels?
Have you try other sizes?
BTW, Your setup look fucking nice!
