Side by Side Forscan Comparison - European vs North American Mustang
GrabThatBlue
Between Canada and Europe
Alright, so I compared line by line, my Canadian Mustang vs @Fruitstang German Mustang and these are the differences.
There were some differences that I found that were not factory settings from Fruitstang because he enabled Shiftindicator/Performance shifting and walk away lock, but for most things, they are factory setting where you can see the differences side by side.
There are some interesting lines that we can enable/disable, depending on if you are NA or EU.
I remember Fruitstang and other Europeans complaining about chimes and other stuff.
Here you can see how to disable them.
Under the column differences you can read for example 9 vs 1. These are the differences between the German and Canadian Mustangs. I hope you understand the way I described this, otherwise you are going to get confused.
WARNING:
This does NOT mean, that if you find something interesting, you can change only that line to make it work. Many options and features on our Mustang need different lines on different modules to get things to work. So don't just copy and paste the line you found interesting and change it on your car. Instead, copy that line, save it to your file and search for other lines in different modules that are from the same subject.
Example:
Autolock feature: To enable this feature you need to change the BCM, IPC and APIM.
IPC GermanyIPC CanadaDifference
720-01-02: CE97 8A720-01-02 CE17 809 vs 1 = Fuelmeter ascending/descending depending on driving style ON vs OFF | A vs 0 = Frost tell tale On vs Off
720-02-01: 49BD 1104 12720-02-01 49A5 1904 12B vs A = LKA EU vs NA | D vs 5 = Lane Departure Warning Tell Tale Off vs On | 1 vs 9 Emergency Assist On vs Off
720-02-02: 4846 01720-02-02 4804 0146 vs 04 = Rear brake management (RBM) On vs Off + Fog Light On vs Off
720-03-01: 7302 6C00 00720-03-01 6102 6C00 007 vs 6 = Speedo EU vs NA | 3 vs 1 = Upshift On vs Off
720-03-02: DC88 00720-03-02 D808 00C vs 8 = TPMS EU vs NA | 8 vs 0 = TSR On vs Off
720-04-01: 1113 0386 00720-04-01 0013 0102 001 vs 0 = Numeric vs Graphic view | 1 vs 0 = Low Beam Fault Indicator On vs Off | 3 vs 1 Shift Indication On vs Off | 8 vs 0 = Chime Menu On vs Off | 6 vs 2 = EU vs NA logo parking brake on dash
720-04-02: 4245 92720-04-02 4341 924245 vs 4341 = Germany (DM) vs Canada (CA)
720-05-01: A000 0080 00720-05-01 9800 0080 00A vs 9 = DAB On Sirius Off vs DAB Off Sirius On | 0 vs 8 = HDR radio Off vs On
720-06-01: DEEF 867B 38720-06-01 5EEF 967B 38D vs 5 = Countdown Start F1 vs Pro Tree Style | 8 vs 9 = Axle Oil Temp Off vs On
720-06-02: 2C00 00720-06-02 6C00 002 vs 6 = Rear Diff Temp Off vs On
720-07-01: 0000 0100 40720-07-01 0000 0000 401 vs 0 = Navigation Speed Sign Rest of World vs NA
720-07-02: 0100 0A720-07-02 0100 08A vs 8 = Trip Computer Indicator Reset On vs Off
720-09-01: 3042 1544 1D720-09-01 3042 1544 991 vs 9 = SLIF Off vs On | D vs 9 = BAR vs PSI
720-09-02: 2B28 A1720-09-02 2128 A1B vs 1 = Wrong Way Alert and Emergency Call System On vs Off
720-10-01: 3548 0001 00720-10-01 3108 0001 005 vs 1 = TSRNCAPA (EU behaviour) On vs Off | 4 vs 0 = Performance Shift On vs Off
720-10-02: 4102 40720-10-02 0102 4041 vs 01 = Local Hazard Information On vs Off (TCU controls this)
720-12-01: 20C4 0000 02720-12-01 20E4 0000 02C vs E = Continues Gear Display Off vs On
APIMAPIM
7D0-01-01: 8541 006B 80--7D0-01-01 A081 0802 80--8 vs A = (unknown) Log missing | 5 vs 0 = Dual tuner + DAB On vs Off | 4 vs 8 = HD Radio Off + Radio EU vs HD Radio On + Radio NA | 0 vs 8 = SDARS (Sirius) Off vs On | 6 vs 0 = Radio 60 minutes vs 20 minuten On | B vs 2 = AM tuner Off vs On
7D0-01-04: 02C0 0020 00--7D0-01-04 02C0 0000 00--2 vs 0 = Driver Seat Module available vs not available (I have Recaro seats, that's why no DDM)
7D0-02-01: 0416 580B 80--7D0-02-01 0416 500B 80--8 vs 0 = Heated and cooled vs Not available (I have Recaro seats, that's why not available).
7D0-02-02: 0002 00D8 40--7D0-02-02 0002 00D8 00--4 vs 0 = Emergency Assistance Off vs On
7D0-03-01: 4245 1C0D 09--7D0-03-01 4341 1C0D 09--4245 vs 4341 = Germany vs Canada
7D0-03-02: 2300 3A06 00--7D0-03-02 2300 0906 00--3 vs 0 = Bluetooth difference, unknown.
7D0-05-01: 2106 3000 00--7D0-05-01 2186 3000 00--0 vs 8 = Electric Horizon Off vs On
7D0-07-01: 1600 3300 00--7D0-07-01 1500 3300 00--Weight in HEX
7D0-09-01: 6B17 49AC FF--7D0-09-01 6B17 492C AF--A vs 2 = Mirrors autofold On vs Off | F vs A = Remote Start seats On vs Off
7D0-09-02: 004E 9710 1D--7D0-09-02 006E 5700 1D--4 vs 6 = Locking Feedback Audible Off vs On | 9 vs 5 = Lane Change Assist EU vs NA | 1 vs 0 = Wrong Way Alert On vs Off
7D0-09-04: 9249 0000 E8--7D0-09-04 9241 0000 E0--9 vs 1 = Information Chimes On vs Off | 8 vs 0 = Tire Monitor/Pressure Reset Setting On vs Off
7D0-09-05: 0030 0520 27--7D0-09-05 0030 0520 20--7 vs 0 = IACC speed tolerance, Speed Limit Assist Tolerance + using menu while driving Off vs On
7D0-10-02: 01EB 3000 04--7D0-10-02 01FB 3000 00--E vs F = Axle temperature Off vs On | 4 vs 0 = Chime speed limit change On vs Off
IPMA GermanyIPMA Canada
706-01-01: 8E3C 0017 00--8E58 0017 00--3 vs 5 = SLOIF vs SLIF | C vs 8 = Wrong Way Alert On vs Off
706-01-02: 4080 0000 00--4000 0000 00--8 vs 0 = Stop and Yield Signs TSR On vs Off
706-02-01: 6A67 0000 03--6A67 0000 00--3 vs 0 = Unknown
706-02-02: 8050 0000 02--0050 0000 02--8 vs 0 = Data via Network vs via Wires
706-04-01: 0501 0008 FE--0904 1008 FE--05 vs 09 = EU market vs NA | 1 vs 4 = EU vs CA | 00 vs 10 = Lighting RoW vs Canada
706-05-01: 1C0C 0000 00--0C00 0000 00--1 vs 0 = LKA strict (EU) vs not strict (NA) | C vs 0 = TSR EU + Driver Assist GSR On vs Off
706-16-01: 120B 8000 00--120B 0000 00--8 vs 0 = Electric Horizon On vs Off
706-19-01: 3146 4152 50--3146 4136 50--VIN
706-19-02: 3846 4631 52--3843 4637 52--VIN
706-19-03: 3531 3238 36--3534 3330 33--VIN
706-19-04: 3638--3330--VIN
706-24-03: 0000 5234 30--0000 5234 32--Sensor serialnumber
706-24-04: 3533 3035 34--3439 3237 36--Sensor serialnumber
706-24-05: 3000 0000 00--3900 0000 00--Sensor serialnumber
706-25-01: 02E2 02E2 00--02D8 02D8 00--Sensor
706-33-01: F0AA BFF0 7E--00AA BFF0 7E--F vs 0 = Costumer LKS On vs Off
706-33-02: FF80 0000 00--F000 0000 00--F vs 0 = Costumer LCA On vs Off
706-34-01: 0055 4000 00--0055 0000 00--8 vs 0 = Costumer LCA On vs Off
706-35-01: FFA0 0000 00--F7E0 0000 00--F vs 7 = Costumer DAS On vs Off | A vs E = Costumer setting WWA Off vs On
706-37-01: 0000 0000 00--0800 0000 00--0 vs 8 = Costumer IACC Off vs On
BCM DuitslandBCM Canada
726-02-02: 001E 0100 00--001E 0100 01--0 vs 1 = Convertible vs Coupe
726-12-02: 5250 38--3650 38--VIN
726-13-01: C101 4646 31--C101 4346 37--VIN
726-13-02: 5235 31--5235 34--VIN
726-14-01: C102 3238 36--C102 3330 33--VIN
726-14-02: 3638--3330--VIN
726-15-02: 8259 40--8249 40--Tire circumference
726-17-02: 0101 0200 00--0001 0200 00--1 vs 0 = Exterior lights (DRL, Puddle Lights, Welcome Light) behaviour EU vs NA
726-18-01: 0101 0101 01--0101 0101 00--1 vs 0 = Approach detection vehicle Enable vs Disable
726-19-01: 1414 1414 14--1414 1414 00--14 vs 00 = Autolamp Delay
726-19-02: 0202 0202 02--0101 0101 01--2 vs 1 = Autolock Inoperative or not possible vs Enabled (0 is disabled)
726-20-01: 0101 0101 01--0000 0000 00--1 vs 0 = Autorelock Enabled vs Disabled
726-20-02: 0101 0101 01--0101 0101 00--1 vs 0 = Autounlock Enabled vs Disabled
726-24-02: 0202 0202 02--0101 0101 01--2 vs 1 = Honk when locking door Disabled vs Enabled
726-25-01: 0101 0101 01--0303 0303 00--1 vs 3 = Remote start duration EU (shorter) vs NA (longer)
726-26-01: 0101 0101 01--0101 0101 00--1 vs 0 = TRIMSWITCHINHIBIT Enabled vs Disabled
726-27-01: 0101 1402 01--0101 1401 00--2 vs 1 = Autolock Inoperative vs Enabled | 1 vs 0 = Autorelock Enabled vs Disabled
726-28-01: 0000 0100 00--0000 0101 03--0 vs 1 = Honk when locking door Disabled vs Enabled
726-30-02: 0000 1388 01--0000 1388 00--1 vs 0 = Exterior lights (DRL, Puddle Lights, Welcome Light) behaviour EU vs NA
726-31-01: 0000 0000 01--0000 0000 00--1 vs 0 = Behaviour when open door with key, 1 door open or 2 doors open
726-31-02: 0001 0100 00--0101 0100 00--0 vs 1 = Double Lock 2 doors vs 1 door
726-33-01: 0102 0001 00--0102 0001 AA--Error in spreadsheet
726-35-01: 0100 0100 00--0000 0000 00--1 vs 0 = Electronic Steering column Lock Enabled vs Disabled | 1 vs 0 = same as the other line
726-37-01: 0101 1E1E 00--0100 1E1E 00--1 vs 0 = Ambient Light setting 0 vs 1
726-38-01: 0164 0A01 00--0164 0A00 01--0 vs 1 = Park Lamps, side markers Off vs On
726-39-01: 0301 0101 01--0301 0100 01--1 vs 0 = Rear Fog Enabled vs Disabled
726-43-01: 0000 0000 01--0000 0000 04--1 vs 4 = Rear Light only for Braking vs Braking + Turn Signal (EU vs NA rear lights)
726-43-02: 0102 0200 01--0402 0200 01--1 vs 4 = Rear Light only for Braking vs Braking + Turn Signal (EU vs NA rear lights)
726-48-02: 6400 0264 01--6400 0364 01--2 vs 3 = Puddle Lamp EU vs NA
726-55-01: 0301 0F01 00--0301 0F02 00--01 vs 02 = Unknown
726-56-01: 0004 0001 01--0104 0101 01--0 vs 1 = Federal Regulations EU vs NA | 0 vs 1 = Reassignment_Enable_Cfg (REC) Disabled vs Enabled
726-57-01: 0708 0100 02--1194 0100 02--USB and cigarette power enabled after turned off vehicle 30 minutes vs 1 hour and 15 minutes
726-62-01: 0000 0050 00--0200 0050 00--0 vs 2 = Panic Button Disabled vs Enabled
726-63-02: 0001 0100 00--0001 0101 00--0 vs 1 = Remote Start Lighting Disabled vs Enabled
726-67-01: A79D CF01 00--E79D CF01 00--A vs E = Rear Fog Light Enabled vs Disabled
726-68-02: 0101 0101 00--0000 0101 00--1 vs 0 = DDM + DSM module Available vs Unavailable (Recaro seats made it unavailable)
726-69-01: 0001 0100 00--0000 0100 00--1 vs 0 = PDM Available vs Unavailable (Recaro seats made it unavailable)
726-71-02: 0002 000A 00--0102 000A 00--0 vs 1 = Puddle Lamp Off vs Puddle Lamp On
726-77-01: 0000 0101 00--0000 0001 00--1 vs 0 = Instrument Panel Brightness 1 press vs double press (unknown where to press)
726-89-01: 01--all zero1 vs 0 = steering column Enabled vs Disabled
726-90-01: 0039 0000 00--0037--Time after PCM shuts off, 55 seconds vs 57 seconds
726-94-01: 0101 0101 00--0101 0101 01--0 vs 1 = Horn Chirp Disabled vs Enabled
LDCMA DuitslandLDCMA Canada
6F6-01-01 0100 0100 00006F6-01-01 0000 0000 00FE1 vs 0 = Headlight leveling Enabled vs Disabled | 1 vs 0 = Enable vs Disable Deactive lights at certain moments, like in Park, Neutral.
6F6-01-02 0101 0000 00016F6-01-02 0100 0000 00001 vs 0 = DRL deactivate under certain conditions Enabled vs Disabled
6F6-01-04 0000 0000 00016F6-01-04 0000 0001 00020 vs 1 = Foreground_LB_Deactive_Behavior (FLBDB) (unknown)
ABS GermanyABS Canada
760-02-02 0103 0202 0275760-02-02 0101 0202 01723 vs 1 = Vehicle Type Market EU vs NA | 2 vs 1 = Convertible vs Coupe
760-03-01 0201 0405 0279760-03-01 0201 0405 01782 vs 1 = Emergency Brake Light Enabled vs Disabled
760-05-01 45B2760-05-01 40AD5 vs 0 = ECU software settings
Fruitstang
2016 Mustang GT Convertible
Man, St. Martin seems to have definitely not enough miles of road to drive your Stang, so you need to find other ways to keep yourself busy playing with it.
Good for many others though :thumbsup:
GrabThatBlue
GrabThatBlue
You nailed it. I'm not driving this car that much on this island.
- Between 10% to 25% of all vehicles don't have an insurance.
- Between 50% to 75% of all motorcycles don't have an insurance.
- 50% of the motorcycles are doing wheelies between vehicles. It's a culture here for young men.
- Drinking and driving is normal on this island.
- Many tourists in rental cars who are drunk and not aware of the roads
- Sun destroys the car
- Salt destroys the car
- We don't have highways. Only 1 way roads, and we only have 1 main road on the whole island.
- Traffic non stop since there is only 1 main road.
So I drive once a week and then it's washed, under a car cover inside the garage, waiting for me to move back to Europe. I did rust protection and undercoating on the vehicle just for this.
Magic88
Bennington
Good call on the uninsured, talk about Russian Roulette. Has to be frustrating though, anytime it's a sunny day, I'm itching to go for a drive.
