Right eibach’s pro-kit for GT with magneride
jml
france
Mustang GT 650
Hi,
I want to install Eibach Pro-kit springs in my 2024 Mustang GT with magneride but I’m having a bit of a trouble finding the right reference.
I have 2 references that keep popping up:
E10-35-064-02-22 and
E10-35-064-05-22.
I’m hoping that someone who already installed them points me in the right direction….
Thank you !
jml
france
Mustang GT 650
Before asking the forum I did ask ChatGPT, not a satisfactory answer.
I tried Deepseek, here it is:
« Based on Eibach's standard part numbering system and known product variations, here's the breakdown of **E10-35-064-02-22** vs. **E10-35-064-05-22** for your 2024 Mustang GT with MagneRide:
1. **Core Product:** Both are **Eibach Pro-Kit Lowering Springs** for the **2024 Ford Mustang GT (S650 chassis) with MagneRide suspension**.
* `E10-35-064`: Identifies the base Pro-Kit for the S650 Mustang GT.
* `M` (implied in 064): Indicates compatibility with **MagneRide** (Crucially important for your car).
2. **Key Difference (Suffix):** The suffix (`-02-22` vs. `-05-22`) indicates the **market/certification version**:
* **E10-35-064-`02`-22:** This is the **standard US market version**. It meets US specifications and regulations.
* **E10-35-064-`05`-22:** This is the **EU/International market version**. The primary difference is that this variant comes with **TUV certification** for road legality in Europe and other regions adopting TUV standards.
3. **Physical Product Differences:**
* **Spring Rates & Lowering Height:** These are **identical** between the `-02` and `-05` versions. The core performance characteristics (ride height drop, spring rates) are the same.
* **Packaging & Documentation:** The `-05` version will include TUV paperwork/certification documents required in applicable markets.
* **Potential Minor Compliance Tweaks:** *Rarely*, there *might* be an extremely minor adjustment mandated solely for TUV paperwork compliance (like a specific bump stop recommendation), but this does not change the spring's fundamental design, performance, or fitment.
4. **Compatibility & Functionality:**
* Both versions will **physically fit** your 2024 US Mustang GT with MagneRide.
* Both will provide the **same lowering effect and handling characteristics**.
* The `-05` (EU/TUV) version is **fully functional and safe** for use in the US.
**Conclusion:**
** The `-05-22` suffix ** designate the **EU/International/TUV-certified version** of the exact same core product (Eibach Pro-Kit for S650 Mustang GT w/ MagneRide).
* The **only significant difference** is the inclusion of **TUV certification** with the `-05-22` kit.
* **For use in the US:** You can safely use **either** part number. The `-02-22` is the typical US stock, while the `-05-22` might be found from international sellers or if US stock is low. They will perform identically on your car.
* **For use in Europe/requiring TUV:** You **must** use the `-05-22` version for legal compliance.
**Recommendation:** If you're in the US, purchase whichever version (`-02-22` or `-05-22`) is readily available and/or better priced. There is no performance advantage to one over the other for your application. Just ensure the base part number (`E10-35-064`) and the MagneRide compatibility (implied by `064`) are correct. »
