Remote start climate control settings
I know there are 2 climate setting under remote start when enabled - auto and last setting.
Last setting is pretty self explanatory. Auto says it will automatically heat or cool the car depending on whether the ambient temps are under or over 70 degrees.
The problem I'm having is when I leave work it's in the 90s. So when I use remote start with the auto climate selected, its only turning the cooled seats on and the AC only goes to the lowest fan speed. I've also noticed it's not adjust the temperature. So basically, I'm still getting in a hot car with almost no AC going after 5 mins of idling.
I've double checked all the settings and everything seems right. Any idea what I'm doing wrong? It also seems silly that Ford pass won't let you adjust the AC remotely. 😕
