Radar Detector Hardwire Mirror Tap
Hoofprint
2024 GT Convertible
Has anyone hardwired their radar detector using mirror taps? If so, what wires do you plug into. Looking for switched power
Hoofprint
Hoofprint
2024 GT Convertible
I tested the voltage coming from the USB behind the mirror, it is 5v…not enough to power the radar detector. Also tested the voltage in a connector under the plastic behind the mirror on the windshield and it was 7v…still not enough.
bridge4d
Mustang
Is there not a connector with 5 or 6 wires going into the back of the mirror?
Marsalad
Northern NY
2024 Mustang GT ordered
How much power does your radar detector need?
I was hoping to use the USB port instead of a mirror tap.
I‘ve never tested the available voltage in any of the eight or so cars I’ve used mirror taps on. They always just worked.
Hoofprint
Hoofprint
2024 GT Convertible
I tried both the 5v and the 7v, it powers the uniden R3 for a spilt second and then fails.
Marsalad
Northern NY
That’s the same detector I have. It’s paid for itself more times than I can count.
your best bet is running a fuse tap from the BCM
msofka
2000 GT, 2024 Dark Horse
Uniden R3. I actually have one in my vehicle and one in my wife’s Bronco.
My son and my brother also have them.
My wife and I have the same set up- she has a bronco, and I have a DH. Good choices!
longjonsilver
Fargo, ND
2023 Ram 1500 Laramie, 2022 Jeep Gladiator Rubicon
I posted this in another thread
I was able to successfully do a mirror tap for my radar detector. I saw someone do it with a Mach E and when I pulled back the plastic housing I saw the same wiring configuration for the Mustang. I used the white for the hot (red) and the black for the ground and my radar detector now powers up when I start the vehicle. I have a GT Premium.
For reference, this was the thread I saw on the Mach E site: https://www.macheforum.com/site/thr...cam-switched-12v-diy-writeup.3952/post-122401
It works great, no issues. I have an Escort brand that I use
doccoch
Midland, Texas
1967 fastback, 2019 Bullitt
i just tried pretty hard (pulled pretty firmly on the housing) on my Dark Horse. The only thing I could get off was the little tab in the front middle. Any more advice?
longjonsilver
Fargo, ND
I had used a clip tool to push them in so that I could pull it down. It you do pull on it, I would try to get as close to the tabs as you can. It should come down.
stryk3
San Antonio, Texas
Just installed a mirror tap for my R3 on my 24’ GT today. It was pretty easy, thank you for this!
