Oil leak
2010Roush70
Pa
66 Fastback
Has anyone else had any problems with the valve cover gaskets leaking? I just have a little over 400 miles on it and when I got home from work today it was smoking and I found oil sitting right above the headers. This the first time this has happened.
BrianJ77
I think there is another thread on this same subject. That sucks, though. Hate that this has happened to you. I hope it's an easy fix.
2010Roush70
Pa
66 Fastback
Thanks,I appreciate it. I did end up seeing that thread. I'm dropping it off at the dealership tomorrow.
BrianJ77
Let us know how it works out and what the cause was. Obviously this is a poorly sealed/seated gasket, but is it a manufacturing defect or a one off defect? Simple replacement of the gasket should remedy this, I would think. Hopefully will be your only issue.
Ford Motor Company
Official Ford Account
Dearborn, MI
Ford Mustang
Good afternoon. Would you please send over a private message with your VIN and dealer info so I can look into this oil leak concern on my end?
There've been at least two other threads of the same issue. In each case, the covers were removed with new gaskets and O-rings installed.
The covers themselves are plastic and tend to flex more under tension.
There are two series of seals. The first, runs the perimeter of the cover. The others are the O-rings around the spark plugs.
Too quick an installation or torquing the cover incorrectly can lead to problems being seen.
On the S550, it wasn't so much the above, but when they first started out, the bolts had a tendency to loosen.
Sorry to hear you are having problems. What I did was put a fresh sheet of cardboard under the car to trap stuff and let me know. So far so good. Fingers crossed. Toes too !
2010Roush70
Pa
66 Fastback
I took it to the dealership today, so hopefully I hear something on Monday.
