Enhanced alarm system how to do you enable when not equipped originally.
Is this possible?
  • Yes
  • No
Results are only viewable after voting.
danny58612
s650 EB
If you look at the specs for Mustangs with and without the Enhanced Security Package, you’ll see that the upgraded system includes a better alarm with sensors inside the cabin. These are meant to detect movement if someone tries to reach into the car—like if you leave your windows cracked and someone tries to grab something. In that case, the alarm should go off.
From what I understand, these sensors are located in the dome light assembly. I looked at my Mustang (which doesn’t have the package) and compared it with one that does, and the dome assemblies actually look the same.
Sure, you don’t get the lockable center console without the package, but I’m wondering if there might be a way to enable the enhanced security features anyway. Ford is slowly rolling out a new subscription service called “Ford Secure.” According to the description, if you pay monthly you can get an enhanced perimeter alarm, and it specifically mentions motion detection.
I’ll include a picture below of what I’m talking about.
They haven’t rolled it out to the Mustang yet—first it was trucks, then the Expedition—but every week I see more vehicles being added to the list that can enroll. So maybe it’s coming to Mustangs soon?
Since my dome light looks the same as the one in cars with the security package, I’m wondering if the sensors might already be there but just disabled.
Does anyone know if it’s possible to enable them through FORScan? The as-built configuration reader doesn’t seem to mention anything about interior motion sensors, so I’m guessing it would require tweaking something deeper in the as-built data.
S650 Mustang Enhanced alarm system how to do you enable when not equipped originally. IMG_0209
The dome may look the same but they are not. They have different part numbers. I found this out on the S550.
Marty1000
massachusetts
Here is a picture of the intrusion module that has to be installed in the overhead console. Inside the module is also integrated inclination sensor and the module communicates over the "LIN" bus to the BCM module. Not sure if the cable harness to the console has the connector for it in a vehicle that does not have the enhanced security option.
S650 Mustang Enhanced alarm system how to do you enable when not equipped originally. Intrusion_modul
danny58612
s650 EB
What if you buy the module would it work?
Marty1000
massachusetts
Assuming that you have the wiring in the upper console for the module you could buy it, but my best guess is that programming will be required to work with your vehicle network. The PATS components in your car would have to work with the new module. Attached is the network diagram and picture of the PATS system in the vehicle for reference.
S650 Mustang Enhanced alarm system how to do you enable when not equipped originally. Network
S650 Mustang Enhanced alarm system how to do you enable when not equipped originally. PATS_INFO
