DH manual misfire P0300/P0302/P0308 - PCM update?
Zbychersky
Poland
DH MT6 + Recaro
Hi,
Last time received couple of times check engine during full acceleration on 4th gear (it happend before and after tune so I don’t think it’s down to the tune).
Code:
===OBD2_PCM DTC P0300-P===
Code: P0300 - Random Misfire Detected
Status (-50):
 - Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II (PCM)
Diagnostic Trouble Code details
This DTC may be caused by :
Ignition System
Fuel System
Low Fuel Warning
Blocked kinked or crushed fuel lines
Fuel contaminated
Evaporative emission control system malfunction
EGR system fault.
Base engine fault
Check for any other codes that may cause a misfire.
===END OBD2_PCM DTC P0300-P===
===OBD2_PCM DTC P0302-P===
Code: P0302 - Cylinder 2 Misfire Detected.
Status (-50):
Ignition System
Fuel System
Fuel contaminated
EGR system fault.
Base engine fault
===END OBD2_PCM DTC P0302-P===
===PCM DTC P0300:00-64===
Code: P0300 - Random/Multiple Cylinder Misfire Detected
Status (-64):
 - DTC Maturing - Intermittent at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
 - Test not complete
Module: Powertrain Control Module
 Freeze Frame  #1:
 Freeze Frame  #2:
-EVENT_TIME: 75168150 s (Sun Jun 21 19:04:11 2026) - Event time
-TOTAL_DISTANCE: 19544 km - Total Distance
-FUELSYS: OL - Drive  - Fuel System Status (Open/Closed Loop)
-LOAD: 98.43 % - Calculated Load Value
-ECT: 89 °C - Engine coolant temperature
-SHRTFT1: 0.00 % - Short term fuel trim 1
-LONGFT1: -0.78 % - Long term fuel trim 1
-SHRTFT2: 0.00 % - Short term fuel trim 2
-LONGFT2: 3.91 % - Long term fuel trim 2
-MAP: 95.0 kPa - Manifold absolute pressure sensor
-RPM: 7081 1/min - Engine Revolutions Per Minute
-VSS: 202.0 km/h - Vehicle Speed
-SPARKADV: 22.50 ° - Spark Advance
-IAT: 26 °C - Intake Air Temperature
-RUNTM: 1170 s - Time Since Engine Start
-RUNTM: 1170 s - Engine Run Time
-FRP: 18980.0 kPa - Fuel Rail Pressure
-EVAP_PCT: 95.69 % - Commanded Evaporative Purge
-FLI: 47.06 % - Fuel Level
-BARO: 99.0 kPa - Barometric pressure
-VPWR: 14.02 V - Control Module Voltage
-TP_REL: 83.14 % - Relative Throttle Position
-TAC_PCT: 92.16 % - Commanded Throttle Actuator Control
===END PCM DTC P0300:00-64===
===PCM DTC P0302:00-64===
Status (-64):
 - Test not complete
 Freeze Frame  #1:
 Freeze Frame  #2:
===END PCM DTC P0302:00-64===
===PCM DTC P0308:00-64===
Code: P0308 - Cylinder 8 Misfire Detected
Status (-64):
 - Test not complete
 Freeze Frame  #1:
 Freeze Frame  #2:
===END PCM DTC P0308:00-64===
I found this technical service bulletin SSM 53215, so I carried out the ‘Forscan Misfire Monitor Profile Correction Learn’ procedure. I haven’t had a chance to check yet whether it helped, but I’m wondering if there’s a PCM update related to this issue? As far as I know, the tuner hasn’t altered the knock detection strategy.
S650 Mustang DH manual misfire P0300/P0302/P0308 - PCM update? 1782134988517-a7
Here’s some information about my PCM:
  • PCM Part Number: PR3A-12A650-SC
  • Calibration Level: PR3A-12A650-SC
  • Strategy: RR3A-14C204-AVH
  • Hardware: PR3A-12B684-MC
Could someone please check if there have been any updates relating to misfire monitoring?
Yamazuki
North Dakota, USA
Just returned home from roughly a 2000 mile trip out to Colorado and back. Had misfire codes pop up on several occasions while in Colorado. However it was usually a P0304 code with the last occurrence being both P0303 and P0304. I find that I can pretty consistently trigger the engine light to flash if I use a low gear and hold RPM's steady (not accelerating or decelerating) in the 3000 to 5000 range.
Dealer will be getting a call tomorrow.
Zbychersky
Zbychersky
Poland
DH MT6 + Recaro
After calibration, today I received misfire on cylinder 8:
Code:
===PCM DTC P0308:00-26===
Status (-26):
 - DTC Present at Time of Request
 Freeze Frame  #1:
 Freeze Frame  #2:
-EVENT_TIME: 75858554 s (Mon Jun 29 18:51:19 2026) - Event time
-TOTAL_DISTANCE: 12533 miles - Total Distance
-LOAD: 98.82 % - Calculated Load Value
-ECT: 198 °F - Engine coolant temperature
-LONGFT2: 4.69 % - Long term fuel trim 2
-MAP: 13.6 psi - Manifold absolute pressure sensor
-RPM: 7265 1/min - Engine Revolutions Per Minute
-VSS: 127.4 mph - Vehicle Speed
-SPARKADV: 26.00 ° - Spark Advance
-IAT: 93 °F - Intake Air Temperature
-RUNTM: 1183 s - Time Since Engine Start
-RUNTM: 1183 s - Engine Run Time
-FRP: 2808.0 psi - Fuel Rail Pressure
-FLI: 85.10 % - Fuel Level
-BARO: 14.2 psi - Barometric pressure
-VPWR: 13.85 V - Control Module Voltage
-TAC_PCT: 93.73 % - Commanded Throttle Actuator Control
===END PCM DTC P0308:00-26===
ZXMustang
tooner
Unless you just tipped out of the throttle, this is a problem. You should be in closed loop fueling unless you go into tip out DFCO for a few seconds. If this was at WOT during a pull, then you might have issues with a wideband.
Your fuel trims are lopsided. Driver's side is adding more than the passenger side. But the more I look at the shorts, you were probably in DFCO when this happened. Thats decel fuel cut off from tipping out of the throttle after being in enrichment. I bet the misfires are just harmonics or false. If its not misfiring at idle or normal cruise, then I'd be calling this false.
ZXMustang
tooner
nvmd. I misread your post.
