Cluster add-on?
Nv6974
Mustang GT
When adding the trip 2 to the cluster, it never stays, once you turn it off and restart car it goes away. Is it supposed to stay or not? Apologies if this question is a repeat, haven't had time to keep up with all the post/questions on here, too busy enjoying new ride!!!!
Thanks for your help in advance!
Bikeman315
Myrtle Beach, SC
2019 Mustang GT/CS
From the owners manual. The first part makes it appear that the computers do not reset until you reset them (just like on the S550).
But I'm guessing your issue is in the configuration part (that the S550 does not have).
ACCESSING THE TRIP COMPUTER
The trip computer is available as a configurable screen in your instrument cluster. See Customizing the Instrument Cluster Display (page 114).
Once the screens have been added, use the instrument cluster display controls on the steering wheel to view each trip screen.
RESETTING THE TRIP COMPUTER
  1. Press Settings on the touchscreen.
  2. Press Instrument Cluster.
  3. Press Trip 1 or Trip 2.
  4. Press Reset Values.
  5. Select which values to reset.
CONFIGURING THE TRIP COMPUTER
  4. Press Configure View.
  5. Select the views you prefer.
Note: There is a minimum of one and a maximum of 4 items that can be selected at one time.
wilkinda65
Sun City Center, FL
I have both added and mine does not disappear like that.
myvaporblue5.0pony
Harkers Island, NC
2024 Mustang GT Premium/Vapor Blue/PP/401A
I have tried to change mine multiple times to no avail. Also, there is nothing that says "Reset Values" or "Configure View" in the list of options that I did not notice in the times that I tried. I will try again to double check.
JimC
Howell, MI
Mine has the same issue. For some reason settings are not held after turning the car off.
Interstellar
Dallas
C6 Z06
I've set mine up to remove the Trip 1, and it just goes away even with personal profiles enabled.
Surprised there hasn't been an OTA update yet but I guess I'm the clown for actually thinking Ford would do anything like Tesla
scazea
Arlington, VA
Same thing happens to me. Any change like adding the Trip 2 will reset after I turn off and exit the car.
I ready somewhere that it has to do with the Profiles being enabled...i have not tested disabling profiles yet...
