Changing mode in climate control
martin
New England
Ecoboost; coupe; guard; dark-saddle; MT; PP; Nav;
How do you change the vent used , say feet to face level , once you have set the temp?
Carter1776
Indiana
2024 Mustang GT Atlas Blue
If you tap the little icon in the center that shows which vent is currently being used, it’ll pop up a larger menu and let you pick a specific zone.
LETHAL
From the D but in the NC
From the D to NC
Just gonna say it...
HVAC controls need knobs and buttons.
I like tech.. but... the set up is annoying on the 650.
Carter1776
Indiana
i agree, i dont use mine super often tbh, but when i do go to change zone, its a little rough.
Back2Gas
When climate controls were controlled manually, I agree.
Nowadays I just set a temperature and forget about it.
LETHAL
From the D to NC
You have a good point. I will also counter. Adjusting fan speed or shutting off the system, shouldn't be a two step, take your eyes off the road process.
First world issues but, annoyances none the less.
Back2Gas
Yeah we need a better way to shut the system off. When I roll the windows down I have to navigate into either the fan and set it to 0 or navigate to the climate control and hit the off button. I’m going to try to use Alexa or voice commands to see if that works
Steadyvw
2019 mustang ecoboost
Actually, the voice commands feature works pretty well. After struggling to navigate to specific features, I just found the correct voice command and problem solved immediately.
S650 Mustang Changing mode in climate control SmartSelect_20230923_195703_FordPass
