- Joined
- Mar 11, 2025
- Threads
- 38
- Messages
- 2,904
- Reaction score
- 3,444
- Location
- New Zealand
- Vehicle(s)
- 2025 Mustang GT
Does this apply to MW50 though? I did none of that, I used the jet recommended by the tuner and ran the pump at 6 - 9psi over max boost, the jet was pre blower so distribution was not an issue. I put static timing back to stock instead of 6 dgrees retarded that Sebring said, and plug readings were always fine. When I was able to check AF ratios it was good at WOT through the rev range. ( Not on a dyno), it ran fine for many years without attention. I did have a circuit that triggered a warning light if the pumps failed to run.Meth setup/tune is more complicated (you have to pull fuel for the meth you add)
Chance that something goes wrong with the meth system, pump failure, clogged jet, doesn't turn on...
Your intake manifold was designed to flow air, not water mist/meth, you end up with unequal distribution
Most people will say you can't push meth+93 as far as you can e85
It has a few advantages, though. You can keep your existing fuel system since water/meth is all supplementary. Where with e85 you need bigger pump(s), injectors, etc at a certain point
It may not be a popular system these days, but it was well proven in aviation piston engines.
