Brake Pedal "creak" Noise
DarkkMatter
Virginia, USA
At 1750 miles I finally got the dreaded brake pedal creaking noise. Not a big deal, but somewhat annoying.
Gonna try some WD-40 on a few mechanical connections. Once I find the culprit I'll use mechanical grease on it.
Unless someone else has found a fix for it.
Jmatech
Tennessee
2034 Mustang Dark Horse
I have the same going on, drives me insane. I really only hear is at very slow speed stops but it’s annoying to hear on a new car. Please update if you locate it, I’d like to address amine as well. If I find mine first I’ll come back here and update as well.
Does this creak happen when you are stationary, holding it on the brakes and very slightly ease the pressure to let the car creep forward?
If so, mine does it, and it's only a resonance of the pads vibrating on the rotor.
DarkkMatter
DarkkMatter
Virginia, USA
I hear it when I'm near a stop, not when driving above 15mph or so, and it doesn't always do it either. It is intermittent.
If it's not a metallic scraping sound it's usually pad noise and nothing to worry about. We used to use CRC Brakleen on the pads to get rid of it.
