24 Dark Horse high frequency highway vibration
Shneakyman
SC
2024 mustang dark horse
Hello all, purchased my 2024 mustang dark horse a few months ago and recently within the past 2-3k miles it has had a pretty noticable high frequency vibration starting at 60-65mph and getting worse as speed increases. Feel it more in the chassis of the car( floor, doors, console, roof) not much in the steering wheel. Pressing the brakes doesn't change it and can put the car in neutral without any change. The vibration is also accompanied by a low rumbling/hum noise, almost like bass feedback. Dealership has had it twice for almost a month. They have "rebuilt" the rear diff, replaced the driveshaft, and balanced and replaced tires. Nothing has helped the vibration and I have been told that's just how Mustangs are.
I'm pretty confident that it is in the drive line but haven't seen many that have successfully fixed an issue similar to this. A few filed lemon law but I have seen one that they replaced "the back whole axle" and that's all the info they gave. Wasn't sure if anyone has experienced this or knows anyone who has. Just trying to help point Ford in the right direction. Thanks! Oh and car has 29k miles, non HP, and stock other than an X-pipe.
Shneakyman
Shneakyman
SC
Could be a wheel bearing... do a couple of quick side to side turns and see if there is more noise to one side or the other.
Doesn't change side to side. And the dealer checked all 4 and said they were good.
@Shneakyman ..... so you have an X pipe. Did your DH come with this? X pipes are known to have "special effects" aka rumble, vibration, etc. at certain rpm/mph ranges. H pipes don't seem to be prone to the "special effects" afflictions of X pipes. Do you know the history of your DH? Was it ever in an accident? Have you had a 4 wheel alignment which should rule in or out frame damage - even very minor frame damage or suspension damage from an accident can cause vibrations/noises at different speeds.
Shneakyman
Shneakyman
SC
It came with the x pipe, and putting the car in neutral doesn't change the vibration which should rule that out. The car has a clean car fax and has had two alignments since I have owned it. None of which showed any issues in that regard.
Grumpywizards
Mo
2025 mustang gt
You're right up there on milage where I would do a transmission fluid change so ask them to just drop the pan and take a look inside. Mine did it and it turned out to be the part that the half shaft pushes into the differential, the gasket had torn so it became metal on metal. You have to pry them off so its not a normal thing people just replace. I'll link it.
https://share.google/sIdQf7AIRfn1KVMhU
@Shneakyman ..... good news on the alignments. Putting the car in neutral is not the same as driving it at highway speeds. I have heard a number of owners say X pipes caused noise and vibrations. I do like @Grumpywizards suggestion!
Shneakyman
Shneakyman
SC
That's on my radar but the dealership wants $1300. As a technician (not Ford) I can just do it myself when I get some free time. And they just rebuilt the rear diff and didn't mention anything about half shaft issues. I'll ask them about it though, thanks!
Shneakyman
Shneakyman
SC
I apologize for not being specific, it is put in neutral while driving not just sitting still. So it is still at highway speed when in neutral and the vibration doesn't change. Also the x pipe has been on the car since I bought it and haven't had any issues until a few thousand miles ago 🤷
@Shneakyman ....got it, but by putting the vehicle in neutral are you not taking the load off the X pipe, even at highway speeds? Respectfully, not trying to be a pita - just hoping to help you solve this annoying issue. If you can't solve this issue at the Ford dealer could there be a local Mustang group where someone has replaced their factory resonator with an X or H pipe and still has the resonator. Maybe you could try that as a last resort?
Shneakyman
Shneakyman
SC
It should eliminate anything related to engine, trans, or exhaust noise. But I'll see what Ford says. This my be my reason to go ahead and get an H pipe, wanted one anyway 😆
@Shneakyman ..... like your thinking! Good luck! BTW my friend had an X pipe. He felt it sounded too raspy and thought it caused tone vibrations inside the cabin at different highway speeds. He replaced it with an H pipe and said the sound deepened and there was no more vibrations. Yes, just his opinion - but maybe.....
Did the dealer put a set of chassis ears on the car and then drive it at the speed the problem occurs? While they are primarily for finding odd noises, vibration can also produce noise and the ears might give an indication as to where the problem is coming from. Just a thought... Good luck!
