2025 Mustang GT coupe vibration at freeway speeds
Lo Pony
N. Alabama.
86, 88, 95, 2016 GT 5.0, 99 Cobra modded still own, ‘19 GT, PP A10, love it.
Brought mine to two different dealerships. Neither dealership came up with anything. One dealership blamed the continental tires.
2018 or later? They should already have the better parts to address this. NVH is probably quite a bit higher on your car also due to different bushings, etc.
Terminus
Alaska
25 400A 6-Speed Black/Black Nite Pony Performance Exhaust
Darn, sorry to hear the hassle you're going thru. No such issue with mine so it should not have the problem. Stay on em'. Hopfully it won't come to lemon law but hey you would have had the use of this vibrator & then a new stang which odds are it won't be a lemon! 😉
Stricklin78
KC
2025 GT
I have a 2025 GT manual. My car has a mild vibration for 30 minutes on the freeway till the car warms up then goes away. Its not the wheels and tires because I swapped them out and still does the same thing. It's not the motor because when I put it in neutral still does it. I am leaning on brakes or shocks. Not sure. My car has 2k miles on it.
Mu2ken
CA
2025 Mustang GT auto
I had a new 2025 GT hardtop auto with the performance package 3:55 gears, adjustable exhaust, Brembo's. Since day one the car had a horrible vibration at 60 mph and higher, really bad at about 80-85 mph to the point the rear view mirror on the windshield literally buzzed and the image was not viewable, it was so bad it actually created a droning sound throughout the interior of the car. Ford balanced the tires multiple times, swapped the driveshaft and was never able to make it any better at all. Ultimately they bought the car back at full price no questions asked so I'm assuming they knew they had an issue with no know fix.
Hobart1
czech republic
Mustang Dark Horse
Hello everyone who had a similar problem to me, vibrations in the rear of the car, described in the thread. The first time a year ago they replaced my cardan shaft at Ford, it helped partially, but it wasn't the core of the problem. This year in Ford replaced my "back whole axle" and we waited for the part for 2 months. In the car, even at 100km/h, it's quiet now and peaceful, unbelievable. At high speeds, there's complete silence from the rear axle. Unfortunately, the service didn't give me a list of the parts they changed, I only know that they replaced the entire rear axle.
I assume your car is a GT? Base or PP?
Can you find out exactly what they changed? The rear drive/susp is independant, so the axles are only the two drive shafts from diff to hubs.
Shneakyman
SC
2024 mustang dark horse
Were you able to find out what parts were replaced? Have this exact same issue on a 24 dark horse and they can't figure it out. Trying to see if it's in the rear diff or the axle shafts causing the vibration.
