Austincreek
Virginia USA
Mustang S650, Tesla Y
For those that are thinking about installing rear camera inside the back window, I found that routing the wiring through the headliner is the way to go.
Use a wire snake and it can go through all the way from the front to the back. You would need to gently navigate thru some reinforcement structure under the headliner but it’s not difficult at all.
S650 Mustang Dashcam rear camera wiring tip -- route wire through headliner IMG_9305
S650 Mustang Dashcam rear camera wiring tip -- route wire through headliner IMG_9304
Paul's stable
Maple Ridge BC Canada
Thank you great tip that is a lot easier than taking down panel pieces.
I've always used a fish tape to get any wiring run under a headliner.
DCS
Ocala, FL
What type of snake did you use?
DCS
Ocala, FL
Looks too stiff for headliner routing, then I've never done that
Don't tell that to my F150 with front and rear dash cams.
They flex enough to contour the roof but are stiff enough to go the direction you want.
Mastermind46
Denver
Thank you for sharing. I have been wanting to do this but didn’t really know how without pulling the liner.
