Whipple & mt82
Alexk
Ontario canada
1972 f100
Im just looking into the whipple kits does anyone know if the mt82 holds up to the power and what else might need to be upgraded along the way
Upacurb
Up a curb at cars and coffee
are you going to launch it on slicks/ radial or just do 60mph roll races?
Half shafts. Maybe drive shaft. Do it up front or wait for it to grenade and do other damage.
Personally, I'd also do some suspension changes.
Alexk
Alexk
Ontario canada
1972 f100
what suspension work would you consider ive got a pp car i was also thinking the steeda rear end braces my main concern was will the clutch and trans hold that extra 300 ponys
Ryansomething
2024 Mustang
Personally I would do the whole stop the hop kit from Steeda, drive shaft and half shafts. Worth while insurance and safety. Plenty of videos of fast mustangs with stock suspension reacting poorly lol.
Bybotie
Dallas
2024 GT Premium, PP
It will handle the power. The tires will save the trans. If you put slicks on it and launch hard on a prepped surface, you might ride home next to a tow truck driver.
Deleted member 17846
Guest
You don't need to do anything as suggested for your driving.
Half Shaft upgrades are not needed unless you plan on launching the car HARD with slicks/drag radials.
Suspension will also be based on how you plan on driving the car or plans down the road.
Again, you don't have to do anything but bolt the kit up and go. But once you start pushing the car hard you might want to upgrade some things.
I'd plan on upgrading the clutch as you will most likely wear it out fast than stock.
LethalPerformance
Fl
We've been beating our manual GT up for quite sometime with the Stage 2 Whipple kit and 3.50" pulley. Last time the car was on the dyno with some octane booster it made 833rwhp. It's been to the track once and handled everything just fine. We run the Gforce Outlaw axles on that car along with a QA1 driveshaft. I definitely feel the axles are a must if you plan on being hard on the car. Regardless of whether it's on the street or track those will help prevent breakage if any wheel hop is present.
Since our last track outing we have made a few upgrades to the car as we are planning on turning it up with the 3.250" pulley. Ben Calimer was nice enough to offer me a built stage2 transmission along with the 26 spline input shaft upgrade. Since we changed the spline to 26 we needed a new clutch. So Mcleod built us a RXTHD for the car with 26 spline discs. I've got an MGW shifter in there too which feels way better than the stock shifter. Lastly we finally did some shocks and struts since it's a non magneride car. We put on the Kelltrac adjustable front struts and some Viking double adjustable rear shocks. Just putting some break in miles on the clutch now and we should be back to the track once the weather cools down a bit. (If that ever happens down here in S. FLA)
If you need any help with getting a setup together give us a shout and we'll be glad to assist you.
brownbear313
winsted CT
2020 mustang GT
How is the calimer trans holding up? What is the ceiling on that? Have you guys got any times I have a similar build and debating which way to go with the transmission a calimer or t56xl
Paul's stable
Maple Ridge BC Canada
I have a Whipple and a Tremec in my Dark Horse all I did was put in DSS 2000 HP rear axles at it runs great.
schmeky7
West Monroe Louisiana
2018 Mustang GT, 2024 Mustang GT
Alexk,
Don't waste your money on axles or drive shaft. If you are a "cruiser", you should be fine. My 2018 GT makes 780 to the wheel (A10) and my axles and drive shaft have held up perfectly for 22K miles boosted (36K+ total mileage).
I have had 24 roll-on's from roughly 60 mph and car is as tight as the day I bought it.
