Wheel Question
Paulino698
Temple Tx
2024 Mustang Gt Premium
So I was wanting to get some new wheels and I was thinking about getting rtr tech mesh 19x9.5 in the front and 19x10.5 in the back does anyone know if they would fit on my tire they’re 255/40/19
10.5 wide rim might be to wide depending on the tire manufacture.
You should be ok. It would be best to look up the brand tire and find out the rim width range. I had your tire size on my 2011 that had 9 inch wide rims. Going 1/2 wider should be fine.
Dena
Phoenix AZ
My car came with 19x9.5R/10R rims and 255F/275R/40R19 tires. I can't say if there is a difference in the wheels or axles on the dark horse and the other issue is the PP uses even bigger tires. I don't know just how big you can go but even with the standard tires I have, things are close.
Attached is a fitment guide that could be of help.
Project6GR Wheels
Los Angeles, CA
Shelby GT350R
255 on a 10.5 will have a stretch on the tire, would recommend at least a 275/35 - 295/35 on a 10.5 for the rear
