Warranty
Actual Whipple warranty.
Supercharger & Powertrain WarrantyWhipple Superchargershttps://whipplesuperchargers.com › pdf
Install headers? Warranty gone.
"The use of non-Whipple approved accessories, such as, headers, air induction, unsupported fuel additives, camshafts, nitrous oxide systems, and other aftermarket products."
Put on sticky tires? Warranty gone. See F in the exclusions and limitations.
Now on to the drivetrain warranty:
Below are those vehicle components covered and not covered under this warranty:​
ENGINE COMPONENTS
COVERED: Pistons, piston rings, piston pins, crankshaft and bearings, connecting rods and bearings, camshafts and bearings, timing chain and gears, intake/exhaust valves and seals, valve springs, oil pump, push rods, rocker arms, rocker arm shafts, lifters, and superchargers. If a failure of any of these parts damages either the engine block or cylinder heads, a remanufactured long block assembly will be provided up to the maximum coverage of $7500.00 (USD).​
NON-COVERED: Those engine components specifically not listed including, but not limited to, parts, filters, idlers, belts, electronics, etc., that are required to be replaced as a part of the vehicle’s normal maintenance schedule are not covered under this warranty.​
TRANSMISSION COMPONENTS
COVERED: Torque converter, oil pump, governor, bands, drums, planetaries, shaft(s), sprag(s), bearings, shift rail(s), fork(s), and synchronizers.​
NON-COVERED: All-wheel drive vehicles are excluded from transmission coverages under this warranty. Failure of related parts external to the transmission that cause a transmission claim, including but not limited to, transmission coolers, levers, controls, electronics, etc., void coverage under this warranty.​
FRONT AND REAR AXLE IS NOT COVERED
TRANSFER CASE IS NOT COVERED
SUSPENSION IS NOT COVERED
EXHAUST IS NOT COVERED
Our total liability per covered vehicle under this warranty is limited to $9,500.00 USD (aggregate). Each covered component has its own aggregate value which when combined equals the total liability per vehicle. The engine is covered for $7500.00 USD and $2000.00 USD per transmission. These amounts cannot be combined together to aid in the repair of another covered component. In the rare case when the repair cost exceeds the actual cash value of the vehicle, we will refund the purchase price of the Whipple Supercharger kit(s) once the complete kit is returned prepaid to us.
In the event that the amount of any one authorized repair or the combined total amount of all authorized repairs meets or exceeds Our liability, Your Program will be deemed expired, and no further coverage will be afforded to You, regardless of the remaining time or mileage of Your Program’s Plan Period.
135Hoser
2024 Dorkhorse, 2024 CR-V
So you get back what you paid for a supercharger in the form of warranty if your motor does fail.
Use the warranty if you need to. If after a couple years your motor is still holding up, then modify further. Also lots of stories about the 10R80 eating itself so the transmission warranty (though limited) is nice to have as well.
Also I might have gone a post without mentioning this, but my cats melted on my stage 1 whipple tune, so...
Stolen from Facebook, somebody else's post:
I currently elected to go with the Whipple Gen 6x Stage 1 with the Whipple PowerTrain Warranty over the Ford Performance Whipple. My reasons why:
1. To have the latest Gen 6x Whipple unit/technology.
What does that mean? They are the same supercharger other than the sticker on the lid
@Lou G ..... regardless of any state's consumer protection act assistance unless a consumer has deep, deep pockets to hire experts and lawyers they have zero chance if they have modified any product. This is not to be confused with clear manufacturer negligence that resuts in class action lawsuits etc.
Luckily we have a cheap Consumer Disputes Tribunal which hears cases up to $NZ60,000. No lawyers, just claimant and defendant.
It's been useful to me a few times.
