Traction control in Race and Drag modes (DH)
npole
Italy
Mustang Dark Horse 2024
I see that when customizing the profile, you can select the Race and Drag mode as base, but then you can individually set the exhaust, traction control, steering wheel.. but when turning on the traction control and saving it in the profile, the dashboard shows it off. How does it actually work? If I select the Sport mode VS the Race mode with the traction control ON, what's exactly the difference?
Aggressiveness of assistance
npole
Italy
Cool, then even while the lamp on the dashboard shows the TC is off, there's some sort of it working (but less aggressive).
Depends on the ‘mode’, unless all off nanny can remind / interfere.
Alan Applegate
Roswell, NM
Even if you turn off both traction and stability controls, the 'system' is still lurking. You can completely disable them by unplugging the Dyno plug atop the left inner fender.
