Question on Performance Pack S650 vs. S550
Dave2013M3
El Segundo,Ca
2020 Ford Mustang GT Base PP1
The S550 PP had upgraded oil coolers and a larger radiator. Does the S650 also follow that route?
Baldilocks
Delaware
If you go to the build site and click on the ā€œiā€ next to Performance Package, it will detail all of the features.
Dave2013M3
Dave2013M3
El Segundo,Ca
I saw that, it doesn't mention it. With the S550 it mentioned it.
S650 Mustang Question on Performance Pack S650 vs. S550 1699578127785
The owners manual mentions slightly larger radiator capacity for ā€˜performance vehicle with automatic transmissionā€™. Pg373
s3ltz3r
CA
22' GT
It seems like it doesn't have it like the S550s. Kinda nuts since it's more expensive. Maybe the money went to the rear Brembo brakes? šŸ¤”
JimC
Howell, MI
It might not be mentioned but it is there. I can see it in the driver side lower grille on my car with performande pack
Dave2013M3
Dave2013M3
El Segundo,Ca
The S550 PP also had an upgraded radiator. Maybe this is all standard on the GT now. However there was a thread where an S650 overheated on track.
2011 gt
PP 2023 coolant capacity 14QTS. PP 2024 coolant capacity 12.8QTS. Slightly less for MT.
s3ltz3r
CA
22' GT
Positive? Because of the dual TBs, Ford had to rearrange the engine parts. Like the PCM is now located on the passenger side front number (below the headlight assembly). A really stupid location, might I add (avoid driving in puddles).
JimC
Howell, MI
Ye
Yes I'm positive. Here are some pictures showing the grille on the driver side, with oil cooler behind it, and the passenger side which is a solid "grille"
Driver side - oil cooler behind the open lower grille.
S650 Mustang Question on Performance Pack S650 vs. S550 driver side grille further back
Driver side close up of the oil cooler through the lower grille.
S650 Mustang Question on Performance Pack S650 vs. S550 driver side grille with oil cooler
Passenger side lower grille, solid (to protect the PCM behind it probably)
S650 Mustang Question on Performance Pack S650 vs. S550 passenger side grille closed off
