Mach 1 Wheels on S650 GT- Fitment Questions
Stanzi
Whitesboro, Texas
2024 Subaru WRX tR
Has anyone installed the Mach 1 Handling Package Wheels on their 2024+ GT?
It’s my understanding you can’t just bolt them on they will rub…
Fronts are 19x10.5 with a 24mm offset.
I got an amazing deal on them so I’m going to try them — $380 New from Ford Accessories after my points and a 20% off code.
It’s my understanding that I need the following:
1) Dark Horse Adjustable Camber Plates
2) Dark Horse or other Front Fender Arch
I have the camber plates - my car is whippled and not lowered.
Anyone else done this? I’ve searched and some were almost successful but looks like they never ran the camber plates…
When I searched the forums the only folks I found that had done this don’t seem to be active any longer and ended up with some fitment issues but weren’t running the adjustable camber plates …
Thanks in advance!
That sounds not far off from the Dark Horse wheels width and backspacing.
The front fender arch is not a necessity but maybe will keep it from looking like it sticks out. I doubt the adjustable camber plates are necessary, either, as my Dark Horse has a street alignment.
Tires matter a bunch. The original Pirelli 305 tires have a narrow tread. I now have Michelin PS4S in the same size, and they are fatter. Still fit.
I have not installed Mach 1 wheels on an S650, but if I had to guess, they are going to fit.
Stanzi
Stanzi
Whitesboro, Texas
2024 Subaru WRX tR
Yeah they are identical in size / specs to the dark horse handling package wheels.
I can’t see how they wouldn’t fit unless there is some inherent internal difference between the Dark Horse and the GT PP.
thanks for the feedback
I do not know if there are any other physical difference between your car and my car in terms of the fenders or fender wells - for instance, the driver side has slots in the fender well to let air out from the oil cooler, which is installed ahead of the tire. If you have the performance package you may have those, too.
As @Junkyard Dog says, keep the front tire size down... brands vary in actual size, even though same rated "size" tire, check specs for actual dimensions.
Stanzi
Stanzi
Whitesboro, Texas
2024 Subaru WRX tR
As I research this more it looks like what might actually be an issue is at full wheel lock / turn- so I’m looking into adjustable steering locks if that is indeed the issue.
I plan on running PS4S.
looking positive- worst case I try them and sell them and get new wheels lol 😝
thanks for the comments much appreciated
For whatever it is worth, I am running PS4S 305/30R19 on 10.5" OEM wheels with no issues. I am just commenting that they are a different size from the same supposed size in Pirelli Trofeo RS (front and rear).
