JPGC_S650’s 2024 GT Build thread
JPGC_S650
JPGC_S650
SC
UPR Catch can and STB installed.
S650 Mustang JPGC_S650’s 2024 GT Build thread IMG_5934
JPGC_S650
JPGC_S650
SC
Soon…these are the Steeda Minimum Drop linear springs. Just wanted a little extra stiffness with a little bit of drop.
S650 Mustang JPGC_S650’s 2024 GT Build thread IMG_5935
JPGC_S650
JPGC_S650
SC
JPGC_S650
JPGC_S650
SC
How would you put the jack bars underneath the car with Quick Jack in the way? I’m curious?
I already added the jacking rails before the quick jack. I used a regular ole jack/ jack stands when I did that. :cool:
JPGC_S650
JPGC_S650
SC
Quick cold start/ idle video with the Steeda H-Pipe and stock active exhaust in normal mode.
IPB
RI
20 GMC Sierra AT4 6.2L, 22 BMX X3M40, 00 Honda S2K
Sounds great, and love that RTR duckbill!
Can't wait to see it after the springs go on!
JPGC_S650
JPGC_S650
SC
Oh this sucker is LOUD, lol, and deep. In normal, sport, and track modes at least. In quiet mode, it’s a lot more tame and removes the drone for the most part.
Flowmaster Outlaw system w/ active exhaust and a Steeda H-pipe.
I’ll get a video added soon. I still need to tweak the alignment slightly after some heat cycles.
S650 Mustang JPGC_S650’s 2024 GT Build thread IMG_5939
S650 Mustang JPGC_S650’s 2024 GT Build thread IMG_5941
S650 Mustang JPGC_S650’s 2024 GT Build thread IMG_5944
S650 Mustang JPGC_S650’s 2024 GT Build thread IMG_5943
S650 Mustang JPGC_S650’s 2024 GT Build thread IMG_5942
S650 Mustang JPGC_S650’s 2024 GT Build thread IMG_5945
TXGT29
TX
Looks great. Looking forward to soundclips. How's the drone, as that is what I was reading from some other's input.
Thanks
JPGC_S650
JPGC_S650
SC
Thanks
There is drone, though not fox body with no cats and Flowmaster 40s or 10s drone. I like some drone so I should remain happy with this kit. Plus quiet mode takes most of the drone away.
TXGT29
TX
Thanks for the note. I don't mind some drone either. And if changing mode with AVE for long trips resolves it, I'm good.
Looking forward to clips. This uses stock mounting locations, right? Seems like the tips stick out farther, but could just be the angle.
Thanks again.
JPGC_S650
JPGC_S650
SC
Yep, the same mounting locations. The tips are larger than stock (4” vs 3.5”) and do stick out a little further….at least how I have it aligned. I could probably push them in a little further but being that the pipes under the car are 3”, there isn’t a whole lot of wiggle room without causing rubbing issues.
JPGC_S650
JPGC_S650
SC
Updated with video:
JPGC_S650
JPGC_S650
SC
Finally got the MGW Race shifter installed. Not a difficult job but quite the annoying install. On to the springs next….
S650 Mustang JPGC_S650’s 2024 GT Build thread IMG_5967
S650 Mustang JPGC_S650’s 2024 GT Build thread IMG_5969
S650 Mustang JPGC_S650’s 2024 GT Build thread IMG_5970
