Ford S650 Mustang Differential to Subframe Bolts Upgrade
Mod Mustang Racing
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
This Bolt kit from MMR replaces the Factory 1 time use (torque to yield) bolts. This kit has addressed the mis-alignment issue by including Chromoly Sleeves to take up the massive amount of slop in the factory rear bushings. This translates into proper rear differential to subframe alignment which helps reduce vibration from mis-aligned or loose fitting differntial housing bolts.
The Bolts exceed OE quality and strength and meet the strict ISO 898-1 specification and testing requirements and have a Tensile Strength of over 150,000psi!
https://www.modularmotorsportsracin...n_page=product_info&cPath=94&products_id=1547
S650 Mustang Ford S650 Mustang Differential to Subframe Bolts Upgrade diff bolts
S650 Mustang Ford S650 Mustang Differential to Subframe Bolts Upgrade diff bolts location
