Convertible Top - Catching Top Half of Seatbelt Housing
Skoons
Orlando, FL
2024 Mustang GT Convertible
Anyone else in the forum with a convertible experiencing this? On the passenger side, there is a small lip on the back edge of the top half of the seatbelt housing. When raising the top, the inside lining cloth catches the lip and lifts the plastic housing off. Broke the clip on the top and bottom plastic bits.
Decio
SE Massachusetts
Not that I've noticed. Can you upload a photo? I wonder if the seat orientation has anything to do with it (not that it should).
Skoons
Skoons
Orlando, FL
This guy, the inside liner gets caught on it and pulls the whole bit half off on the way up.
S650 Mustang Convertible Top - Catching Top Half of Seatbelt Housing F8F8EF1A-BFDA-4994-9569-171E0285AF7E
papaD
canada eh!
No problem with mine...
However, I will check later tonight to see how close it is.
Crew4991
The top is the same as my old 2016 convertible, in the last 7 years I have never had it catch or seen the molding look like your photo OP. Take that to the dealer and have them fix it/adjust it back into the correct spot on their dime.
San Francisco
Mustang 5.0 GT Convertible 2024
I had a similar issue but on the other side ie driver's side rear passenger. Dealership ordered 2 new replacement parts - arrived within days and re-installed. Now perfect. All under warranty
Huntem4
7g Mustang GT convertible
Huntem4
I have the same problem with my 7g convertible. I have to take it in for repair. Was the clip you referenced a defect? What repairs were done?
Huntem4
Huntem4
Do you know the the # on the replacement parts ordered? Having the same problem but on the passenger side
samson
This EXACT thing happened to me at the dealer when I was picking up the car. Hadn't even gotten it out of the lot yet and the edge of the top got hung up on that seat belt housing trim piece. Now the plastic piece is bowed outward and I'm sure it will happen again. I'm going to get them to replace that panel but I like your work around in the meantime.
samson
Yep this is exactly how it happened with mine on but on the passenger side
Nstalgia
Austin
2018 mustang ecoboost convertible
Hey, have you managed to get the part numbers needed to fix this issue? I am having the same issue here and trying to get it properly fixed.
DT-GT
2022 Mustang
Something must be positioned a little off that desired. Fortunately I’ve not had the issue but will watch. Probably several hundred opening/closings on my 2022 and now 20+ on my 2025. No issue. 🤞🤞🤞
