AutoAddict RGB Headlights
So0_NaSTy
NY
2024 Ford Mustang GT Premium
Hello all. For anyone here that by chance has the AutoAddict RGB headlights for these cars, have you noticed your auto high beams no longer work? My regular high beam work, welcome lighting, etc, are all mint with no errors, but I have AHB enabled in settings, and if I push the stalk forward to arm and show that “A”, it just turns my high beams on, not auto. Dial is on auto as well, so not sure what’s going on. Any help would be awesome.
You might try to contact the manufacturer... I noticed you said the electronic box on the light (LDCM) was replaced with the light, which could explain the issue... the auto high beam signal may be carried over the canbus network to the LDCM's, which have now been replaced and may not have proper programming to interpret that signal... just a guess, but the manufacturer could probably tell you if that is the case.
So0_NaSTy
So0_NaSTy
NY
I would imagine that’s it. Probably nothing you can do about it. Not like I can put OEM ones in it. Because 1) I may lose RGB or 2) completely fry the board / module.
