ABS DTC Question
Kaleza
Chicago
2024 ecoboost
Hi, so i connected forscan to my car and i got this one dtc, can anyone with better knowledge explain what this dtc exactly is, and can i just clear it? Thank you
===ABS DTC U0100:87-28===
Code: U0100 - Lost Communication With ECM/PCM A
Additional Fault Symptom (:87):
- Missing Message
Status (-28):
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Antilock braking system
Freeze Frame #1:
-EVENT_TIME: 42426723 s (Tue Feb 25 14:21:49 2025) - Event time
-TOTAL_DISTANCE: 8727 miles - Total Distance
-MODULE_VOLTAGE: 12.0 V - Control Module Voltage
-POWER_MODE: Ignition on power mode - Power Mode Status
-ECU_F_RSC: Inactive - ECU System Flags - Roll Stability Control
-ECU_F_ABS: Inactive - ECU System Flags - ABS
-ECU_F_BTCS: Inactive - ECU System Flags - Brake Traction Control System
-ECU_F_TCS: Inactive - ECU System Flags - Traction Control System
-ECU_F_AYC: Inactive - ECU System Flags - Active Yaw Control
-ECU_F_HDC: Enabled - ECU System Flags - Hill Decent Control
-ECU_F_ESC: Inactive - ECU System Flags - Engine Drag Control
-ECU_F_TSC: Inactive - ECU System Flags - Trailer Stability Control
-ABS: Inactive - ABS
-AYC: Inactive - AYC
-BTCS: Inactive - BTCS -201D
-HDC: Inactive - HDC
-RSC: Inactive - RSC
-BTC: Inactive - BTC
===END ABS DTC U0100:87-28===
