50 Degree Cooler IAT's on Your Supercharged Mustang!
beefcake
Gold Sponsor
Bethel
Check out how the FI Forced Inductions Interchiller lowers your IAT2 temperatures in your Whipple, VMP, Roush and other water cooled superchargers. Awesome results ! Check out the video below !
WHAT IS A FORCED INDUCTION INTERCHILLER?
In simple terms we are T-piecing into the cars AC system and splitting the refrigerant 50/50 between your cabin and chiller. We also install a solenoid on to the line going to the cabin so you have 2 modes of operation:
  1. Cabin and chiller
  2. Chiller only (Race mode)
    Race mode is race track safe as no condensation will leak from the cars cabin evaporator.Our interchiller core is a patented design, one of the many reasons we are able to get so cold and also have ZERO impact on cabin AC performance.
    Your intercooler fluid will pass through one side of the chiller core exchanging it’s temperature with the cars refrigerant, which then results in freezing cold intake temps as the intercooler fluid gets colder and colder.
Product Link : https://www.beefcakeracing.com/fi-interchiller-20upmustanggt500/
S650 Mustang 50 Degree Cooler IAT's on Your Supercharged Mustang! ford-mustang-1
i have some questions about this.
1. where i live, it peaks at about 120 degrees in summer. will this make it take longer for the cabin to cool down? it already takes about 3 minutes on max A/C.
2. will issues pop up with the supercharger, intercooler reservoir, or some other part cracks or otherwise gets damaged due to the temperatures?
3. is there a warranty, and if so how many years and miles is it? i am concerned about potential internal failure leading to coolant getting into the A/C system and refrigerant getting into the intercooler system.
4. how is the solenoid for the normal and race mode controlled? do you have to wire a switch into the cabin, does it read the drive mode, or something else?
I’d like to know can this be turned off completely. Because like most late model cars, you don’t actually control the AC, the car does. No big deal now that Texas is just about done with the pre-heat setting, but for the 6 or so weeks of winter-ish we have, we won’t be needing the chiller at all.
I suppose others who live in climates where humans weren’t meant to live - you know who you are :p may want to not have the ac on for several months.
beefcake
beefcake
Gold Sponsor
Bethel
No it wont run all the time. While it can be used with the AC on for maximum cooling, it also has a "race mode" where it bypasses the cabin This allows for colder intake air temperatures without the need for constant AC operation, good for the track
beefcake
beefcake
Gold Sponsor
Bethel
Wont make the cabin cool down longer with the setup. We havent come across any of those potential issues. FI interchillers has great customer service but i dontbeleive they have any type of mileage warranty. And itll be wired correct
awesome , thank you for the reply. will definitely keep this in mind when i do eventually supercharge mine
beefcake
beefcake
Gold Sponsor
Bethel
Let us know when you are ready we can help get you situated with the Supercharger as well!
do you guys offer custom powder coating on the VMP stage 4?
beefcake
beefcake
Gold Sponsor
Bethel
We do !Give us a call or shoot us a message and we can get you taken care of
