The Solution to Fixing Bump Steer on Your S650 Mustang - Must Have for Lowered Mustangs!
tj@steeda
2015 Steeda Mustang
If you've lowered your 2024+ Mustang, you've probably experienced something called bump steer. This is when your suspension experiences a change in toe under compression or rebound. When you lower your Mustang, your outer tie rod end becomes misaligned with your lower control arm. The Steeda S650 Bump Steer Kit is designed to give you the adjustment you need to fix your suspension geometry. You're not going to find a better kit on the market. Check out the video to find out why!
Product details here - https://www.steeda.com/steeda-555-8179-s650-mustang-bumpsteer-kit
