No IPC module listed
npole
Italy
Mustang Dark Horse 2024
I'm using the latest (2.3.64) version, and the IPC module isn't listed (I'm using a fresh profile). Also I do not have the write option on most PCM values. I own a EU DH.
I'm using an old cable I was using years ago, does the cable may affect what the sw is capable of?
2.3.64 should be able to see and update the IPC. I have a May ’24 build Dark Horse and at first I could see, but not update the IPC, had to upgrade to 2.3.62 or 63 I believe.
I tried swapping cables, etc and that made no difference.
npole
Italy
Will le you know once the new cable (vGate) will arrive on Monday.
npole
Italy
Fixed, it was the cable, with the new one everything is working (enabled the CGD and RemoteRev on EU). Nor only the IPC module wasn't listing, but several others. All good.
Ah, ok. just missing IPC did sound weird. I’m glad you got it working !
MRI204
Italy
www.grena.com
MY2006 GT Roushcharged MY2020 Bullitt L2061 (sold) Q767 Dark Horse R8339
Hi, could you tell me which cable you ordered?
Mine will arrive in a few months and I would already like to have the right tools to change some things with ForScan...! Thank you
