NEW S650 LED Reverse Light and 4th Brake Light | FORM Lighting
Status
Not open for further replies.
Form Lighting
Saint Charles, Missouri
2015+ Mustangs
Form Lighting is thrilled to introduce our new LED Reverse Light for the 2024 S650 Mustang!​
Looking to upgrade the styling of your S650 Mustang? Look no further. Introducing the LED Reverse Lamp from Form Lighting. Add some functionality and stand out from the crowd, upgrading your reverse lamp is one of the easiest things you can do to give your S650 some added functions and a modern appearance on the road.
Upgraded Styling. Available in our smoked finish to match your lower bumper, this upgrade offers a lot more than just your standard reverse light—you’re getting a reverse light twice as bright as the factory option, an additional red running light, and an optional strobing 4th brake light. The Form Lighting LED Reverse Light adds a significant increase in output over the factory reverse lamp as well as a more stealth appearance with a smoked lens. The center section of the lamp acts as a running light and a 4th brake light with the option to add a strobing function if desired. With this premium OE-grade replacement, you’ll stand out from the crowd with an extremely modern look.
OEM-Grade Construction. Form Lighting lamps are built with quality in mind, using OE-grade materials and design techniques. This includes durable UV-coated polycarbonate lenses, automotive-grade LED emitters, breather vents, and OEM plug-and-play connectors. They are assembled in an IATF 16949-certified facility, which is a quality management system designed for the automotive industry. While they may not be the cheapest option you’ll find, you can rest assured that these lights will provide durable and superior performance.
Road Legal. Form Lighting lamps meet all SAE, DOT, FMVSS, and CMVSS standards and regulations for legal on-road use in the United States and Canada.
Plug-and-Play. Our LED Reverse Lamp for the Mustang is completely plug-and-play and will fit perfectly, without any gaps. It was designed to plug into your factory tail light wiring, using OEM connectors, with no cutting or splicing needed. And if you want to disable or enable toggle the strobe effect? It’s so easy—just connect or disconnect the amp connector in the trunk.
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. Any warranty or service needs are supported directly with fast US-based support, and any replacement parts, if needed, are shipped quickly from our US warehouse. In the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Logan Z.
Form Lighting
rbeyer
2024 Mustang GT Base
I got this but the connector is the "type B" one, is there a way I can still install the light?
Diode Dynamics
St. Louis, MO
www.diodedynamics.com
2015 Mustang EcoBoost
Hey there!
We just replied to your other forum thread.
Our team has a harness update coming soon for those waiting.
Status
