[Mustang 2025 Import from USA to Europe 🇺🇸➡️🇪🇺] Full Experience – Frustration, Complexity & Valuable Discoveries
Saint-Maxent
Mustang 7 - EcoBoost Premium - Shadow Black
Hey everyone,
I wanted to share my ongoing experience importing a 2025 EcoBoost Mustang (Gen 7) from the US to Europe, as part of my relocation back home after expat life. While the car is a dream, getting it road-legal in the EU is a nightmare of details. Hopefully, this helps others considering the same path – or at least gives you a sense of the rabbit hole you're about to fall into.
✅ Background
  • Car: 2025 Mustang EcoBoost, US-spec.
  • Context: returning to Europe (France/Luxembourg) after expat assignment.
  • Goal: register the vehicle via a European entity (e.g., in Estonia or Luxembourg) to reduce taxes and simplify import.
  • Challenge: US models are not EU-homologated, even if technically similar to European Mustangs.
⚙ Legal Compliance & RTI (Individual Vehicle Approval)
🔧 Required Modifications:
  1. Headlights: US headlights lack mandatory E-marking.
    • Need to be replaced with CE-certified (E-marked) units.
    • Extremely hard to find – even Ford Europe doesn’t list 2025 parts yet.
  2. Taillights:
    • US models use red turn signals – illegal in most EU countries.
    • Swapping to amber turn signals with E-marking is mandatory.
    • A few German retailers list CE-compliant taillight sets for 2024–2025 models.
  3. Rear Fog Light (mandatory in most EU countries):
    • Absent on US models.
    • My solution: integrate a rear fog function into the reverse light, using a Ford OEM headlight switch (Motorcraft SW-8427 – found in Explorer, Mach-E, etc.).
    • Requires wiring a relay, custom harness, and FORScan config. I have the full diagram if needed.
📜 Customs, Taxes, and Registration
  • RTI in France vs. Luxembourg:
    • France: traditional route, UTAC tests, higher bureaucracy.
    • Luxembourg: simpler in some cases, but still needs E-mark parts and proof of emissions.
    • Rear fog light is mandatory in Luxembourg.
  • Emissions & CO₂:
    • No public CO₂ data for the 2025 EcoBoost yet – even Ford doesn’t provide it.
    • In France, CO₂ data is critical for calculating the registration tax ("malus").
  • Customs:
    • Declaration must happen where the vehicle physically enters the EU (France or Luxembourg depending on your entry point and business setup).
🧩 Useful Parts & Sources
  • Motorcraft SW-8427: OEM switch with rear fog capability.
  • Amber E-marked taillights: found on some German OEM parts sites.
  • Euro rear bumper with fog light slot: available through OEM Ford Germany or resellers.
😤 The Frustration
  • Ford is extremely unhelpful with cross-market part sourcing.
  • No documentation yet for the 2025 EcoBoost in Europe.
  • US retailers won’t confirm if parts are CE-compliant.
  • Navigating multi-country legal requirements, with no centralized guidance.
🆘 Open Questions & Call for Help – Let’s Share Knowledge
I’ve gathered a lot so far, but I’m still looking to validate a few key points, and your experience could really help me (and others who’ll walk the same path):
  1. Front Headlights:
    • Do we absolutely need to replace the US headlights to pass EU homologation?
    • I’ve seen conflicting info — some say it’s mandatory due to beam pattern and lack of E-marking, others suggest the beams may be adjustable.
    • If anyone has passed RTI or TÜV with stock US headlights on a Gen 7 Mustang, please speak up 🙏
  2. Taillights:
    1. If i do the modification myself but without the E mark, it will be ok ?
  3. Rear Fog Light:
    • My setup involves repurposing the reverse light housing + Motorcraft SW-8427 switch + relay wiring + FORScan. Has anyone done similar and passed RTI or TÜV?
If anyone here has successfully homologated a 2024/2025 Mustang (GT or EcoBoost) in Europe, I’d love to hear how you did it — especially where you sourced your headlights and taillights.
Cheers,
Fabien
i dont know about importing vehicles, but i can speak a bit about the technical stuff
1. there is no EcoBoost in Europe. the EcoBoost is limited to the US and Japan market, and some other minor places.
2. taillights should be easy enough to make european compliant due to the wiring between a US and export 2025 being identical or the same. if you find someone to re-pin the connector to a different one, it should be a matter of just swapping out the export tail lights. an alternate answer is Form Lighting's clear or smoked tail lights, because they can do amber indicators and requires no re-pinning connectors.
3. putting in the rear fog light is actually really easy, and the US models are already wired for it, just missing the hardware and have some software components disabled. all of which are easily fixable in FORScan. the hardware needed is the headlight switch with the fog light button and the rear reverse and rear fog lamp assembly.
4. US headlights are manually adjusting via a bolt on the top, where export Mustangs have auto-leveling headlights. adding this auto-leveling is completely impractical due to the amount of wiring needed to be done. though, i am not sure what this really does, if its a replacement for the bolt or what.
5. you may also run into issues with mirror indicators, so be sure to check if you need those too
@GrabThatBlue imported their Mustang, so they might be the currently most qualified forum member to talk about the actual importing part, plus any other small details
