MustangNoob
- Thread starter
- #1
Hi folks,
I just installed the steeda brake lines.
The lines feel much firmer at higher speeds but at very low speeds (< 20mph) seems to be a small “gap” in the pedal. Unfortunately can’t remember how big that “gap” was with the previous lines. But it seems that once the car has enough speed that “gap” is significantly reduced and the lines are much firmer than before.
One thing to mention…Did it without putting the system in brake mode. When bleeding the brakes it threw all kind of errors during the procedure…I did not drive the car but I instead I cleared the closes then put it in service mode and did the bleeding process again. No errors appeared.
Drove the car around , scanned for codes again…nothing showed up.
Anybody has any experience with these lines? @SteedaTech
@krisk I showed a post in the past where you had similar issue with the service mode. How has this been for you so far , any issues ?
