Grabbers Garage
Grabber1
Washington
Years ago on another Forum that is no longer around I had a topic called "Grabbers Shop" for 10 years where I would post off topic stuff that I was doing. 9 years ago I downsized and moved. I had a small home with a 5 car garage built with a 10'-8" high ceiling. It has 2 tandem bays and 1 single bay. This photo shows the 1012 square foot lay out of the garage.
S650 Mustang Grabbers Garage Screenshot_20241120_165257_Microsoft 365 (Office)
Grabber1
Grabber1
Washington
RAINY DAY INDOOR PROJECT
Cleaning and re-sealing the garage floor the last 2 days of the storm. It's a 5 car garage. 2 tandem bays and 1 single bay. 1012 square feet with a 10'-8" cealing. Moved my truck and wife's car outside and the GT to the single bay. Will work on that bay in 36 - 48 hrs after 1st area is cured. Left the Harley Davidson in place and worked around it. 1st I cleaned and blew out all cob webs, bugs, dried froggies and lizards. Scuff sanded existing seal coat surface with 60 grit sand paper to allow for proper adhesion. Scrubbed the floor with hot water mixed with dishsoap solution to remove grease residue from working on cars. Cleaned out the construction joints. Blew out the area again. Then used a 14 inch wide roller and long pole to apply 1.5 gallons of solvent based stinky industrial Cure & Seal 25% UV to the floor.
S650 Mustang Grabbers Garage 20241120_113719
S650 Mustang Grabbers Garage 20241120_113712
S650 Mustang Grabbers Garage 20241120_164610
S650 Mustang Grabbers Garage 20241120_124052
S650 Mustang Grabbers Garage 20241120_144844
S650 Mustang Grabbers Garage 20241120_113638
Very nice! I'm comin' over there to work on my GT from now on! 😆
Grabber1
Grabber1
Washington
Finished my garage floor.
S650 Mustang Grabbers Garage 20241121_190539
S650 Mustang Grabbers Garage 20241122_134854
S650 Mustang Grabbers Garage 20241122_134920
Grabber1
Grabber1
Washington
New LED lights on my 4 post Lift.
timd38
Hudson WI
I went with 4’ LED fixtures and attached magnets to the backside. I then put a master switch at the front of the lift and attached the power cord to the hydraulic line to avoid issue with the lift going up and down. In the picture with the red car you can see the multiple rows of lights.
S650 Mustang Grabbers Garage IMG_6109
S650 Mustang Grabbers Garage IMG_5304
S650 Mustang Grabbers Garage IMG_5996
DevilDog
Northern Illinois
2024 Mustang GT on order
Your garage looks great. :like: I'm jealous.
Grabber1
Grabber1
Washington
Your Magnets must be pretty strong. Looks very functional. My LED light strip has double sticky tape already installed on the back side of the light strip which made installation really easy.
Grabber1
Grabber1
Washington
Changed the oil in the 24' and 09'
S650 Mustang Grabbers Garage 20250108_123047
S650 Mustang Grabbers Garage 20250102_132232
