Disable rear seatbelt chime?
Dxm
NYC
Does anybody know how to disable rear seatbelt chime? When you have a rear passenger sitting there.
Thanks.
Dxm
Dxm
NYC
I wound up following the procedure for the Ford Trucks and it worked. There is no way to disable the warning chime from the settings.
Before following the procedure, make sure that:
* The parking brake is set.
* The transmission is in park (P).
* The ignition is off.
* All vehicle doors are closed.
* The driver seatbelt is unbuckled.
1. Switch the ignition on. Do not start the engine.
2. Wait until the seatbelt warning light turns off (about one minute). You must complete Step 3 within 30 seconds after the seatbelt warning light turns off.
3. Buckle then unbuckle the seatbelt three times at a moderate speed, ending with the seatbelt in the unbuckled state. After Step 3, the seatbelt warning light turns on.
4. While the seatbelt warning light is on, buckle then unbuckle the seatbelt. After Step 4, the seatbelt warning light flashes for confirmation.
* This will switch the feature off if it is currently on.
* This will switch the feature on if it is currently off.
ChitownStang
Chicago, North Shore
2015 Mustang GT Premium
This didn’t work on my manual dark horse
