Can a heated steering wheel be added?
dk_ace
2025 ecoboost
So I’m loving the Mustang, but the one feature it doesn’t have that I’m used to and miss is the heated steering wheel.
Any chance there’s a reasonable way to add one?
D
it's gonna get expensive quick. likely gonna need to swap out your SCCM and clockspring, and of course the steering wheel itself. then you gotta change a bunch of settings in various modules with FORScan to tell it it has a heated steering wheel now. and even after all that, there's no promise it will work perfectly. it's one of those things where buying it with the options you want is easier and cheaper than retrofitting them later
John S
Novi, Michigan
2022 Mustang Mach 1
Just an FYI - My Mach 1 steering wheel came from Flat Rock equipped with the heating element w/wiring, even though I didn't order the option. Ford's no dummy, ForScan can't override the BCM to activate it.
dk_ace
2025 ecoboost
Ok, not a big deal but I thought it was worth checking. Thanks!
karlzhao314
MD, USA
