Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track
Apex Wheels
Gold Sponsor
Bay Area
Mustang
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 734b3c48070302ff44cba80346eb0460cb4cf30a-6932x4621
Your Fastest Lap is Calling!
Our forged Sprint™ line was built to be extremely light while still offering a meaningful strength increase over our flow formed wheels. For those looking to shed as much weight as possible to improve lap times.
➡︎ 10K ton forged 6061-T6 aluminum
➡︎ Stronger Sprint™ spec inner lip
➡︎ Side-milled spokes for reduced weight
➡︎ Massive brake clearance
➡︎ Unmatched replacement program
➡︎ Lifetime structural warranty
➡︎ Independently tested and certified
10K Tons Of Pressure
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track e35c4ce976f0c106fe24d54e0dfdf07859c393c8-1200x900
Our new forgings weigh as much as 120 pounds before machining. To form such a thick blank we require special equipment capable of 10,000 metric tons of pressure. This extreme pressure increases the strength of the aluminum by eliminating porosity and improving the grain structure.
True Motorsport Blanks
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track a4904fe105d705ef936beda523cd38ef1233ad6c-1170x780
Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch which gives us total control over the final product, resulting in exceptionally deep spokes and stronger designs.
Learn more our true motorsport blanks.
Side-milled Spokes
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 3c8b8427681350f24eb273a78f9730f67e201bac-1920x1248
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track cdf47f2b028358fd234ebb0b9f5474a6a574dad1-3840x2160
One of the most significant upgrades to our Sprint wheels is the addition of wider and deeper side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. Side-milling is often deemed cost-prohibitive by others, but for true performance without compromise we believe it's essential.
➡︎ 40-50% Wider
➡︎ 50-100% Deeper
Learn more about our wider and deeper side-milling.
A Stronger Lightweight Wheel
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 551a00784f613a7494f84b1a39946167e436c79b-1024x576
Our forged Sprint™ wheels are lightweight without the strength compromises found on typical lightweight wheels. First, we carved out as much material as possible, then we purposefully added one pound back to reinforce critical areas, creating a stronger inner lip and a higher load rating.¹ What’s the point of a lightweight wheel if it’s fragile?
Weight Optimized
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 2508bca34b3d1feb1a5b7d3a39eb8ffd1c8bf1f6-4612x2596
We conducted extensive Finite Element Analysis (FEA) to reinforce high-stress areas and to remove material where it didn’t improve strength. The result is a wheel that is exceptionally light without the strength compromises found on typical lightweight wheels.
Independently Tested
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 52655da2ebf803704b0306d975835a17e42d4eb5-4627x2603
We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. We chose STL, an independent lab in Ohio, to test our Sprint™ wheels far above JWL standards, including increases in testing duration, impact drop height, and total load.
Learn more about our rigorous independent testing.
Tough Inner Lip
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 7a7338931c86b03a6006c76550d70f0d19dd1b38-1080x702
Introducing the Sprint™ spec inner lip, with a unique channel profile that makes it even stronger than our previous designs. So even though our Sprint™ wheels are pounds lighter than comparable flow formed wheels, the inner lip is 32% stronger.
Learn more about our Sprint™ spec inner lip.
Big Brake Clearance
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 59aaa1ae1798bed9ecdd401ad235aa6187e222e7-1200x900
From day one, APEX has been on a mission to build wheels that clear big brakes. Our new forged wheels are the product of everything we’ve developed over the past 10+ years, including an innovative high-clearance barrel design and vehicle-specific spoke profiles.
Deeper Concavity
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 04eb5adcae3393f7938e01c250a8955b045b79ab-640x427
Our new forgings were redesigned to create extra-deep, concave spoke profiles. Their new shape allows us to make any profile, from flat to deep and everything in between. Each one is optimized for a specific application using 3D laser scans of factory and aftermarket brake kits.
Paintless Knurled Beads
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 76368994aa805ccca5b6eb3af329f1d33c4c2c8a-640x427
Whether it's a day at the track or months of street driving, repeated hard braking and acceleration can make a tire slip along the bead seat and go out of balance, causing vibration. Knurled beads help, but are less effective when painted over. Our forged line features unpainted knurled beads that stay sharp and maximize grip.
Learn more about why our forged wheels have unpainted knurled beads.
Built for impact sockets
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track a7bcc1a0b2d21f4bb95084c93827ae24ba39a402-640x427
Track wheels need track tools. Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All APEX wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast.
Laser-Engraved Specs
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 160df809770ca94c3baa432707b71ef3b7dcc688-3840x2160
As track enthusiasts ourselves, we know how frustrating it is to try to locate and decipher wheel specs that have been hastily hammered into the rim or become unreadable over time. With our new Sprint™ wheels, we chose to invest a little extra and laser-engrave the specs on the barrel, in plain sight, making them easy to find and read. (You’re welcome.)
Additional Features
Hub Centric - All APEX wheels with a 5x114.3mm bolt pattern are purpose built featuring a 70.5mm center bore. No centering rings required.
Center Caps - We don't charge extra for caps and we design our wheels to be interchangeable with the OE cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps.
Forged Enduro Line
The Apex Enduro line consists of the strongest wheels we’ve ever made. These wheels feature our highest load rating and our strongest lip, allowing them to withstand abuse, lap after lap.
➡︎ Heavy-duty Enduro Spec inner lip
➡︎ Stiffer side-milled spokes
➡︎ Stronger 2100 lb. load rating
➡︎ Capless hub design to reduce weight
➡︎ 50% replacement program
VS-5RE
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 1d82b7d1a0c6f5cf35acc26bbd7e7504298258bc-3024x4032
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 3bf5cc9a5b6752b559a25e522867466f200bdb1d-7008x4672
The VS-5RE is the forged Enduro version of our popular VS-5 design. These wheels bring serious strength and durability to the split 5 spoke design that Mustang enthusiasts love and gives endurance racers and hardcore HDPE participants a wheel that focuses on longevity and consistency.
To view all of the VS-5RE fitments available for your Mustang and order your set, Head over to our website via the link below or by clicking any of the images of these wheels.
Learn More
Our Strongest Wheels: Enduro Line Features
Most motorsport wheel designs prioritize reducing weight over increasing strength, but some applications require extra strength. High grip tires and lots of downforce put extra strain on wheels. Pair that with a faster driver and regular load ratings are not enough. Enduro line wheels are about 30% stronger than their RS counterparts.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 61e72d692756614276d238712b920337a3de99cc-1280x832
Stiffer Spokes
Wheel stiffness matters but it gets overlooked and undiscussed. The redesigned spokes of the SM-10RE are about 20-25% stiffer than the Sprint Line version. Stiffer spokes help reduce camber loss, which reduces outer edge tire wear and improves feel and responsiveness.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 4e340ae10c55be1c421aa42c22d6d8c1e902ce41-8203x5469
Toughest Inner Lip
Introducing the Enduro Spec inner lip - our strongest ever. With 50% more reinforcement, these wheels are better protected against the harsh conditions found on (and off) track.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 40f50cc3a46022106c49b3d9fedbfe12bf3c5e91-1280x832
Reinforced Front Lip
We added extra material in the front lip for more durability so you can keep attacking those berms. You can easily spot the beefed up design of an Enduro lip vs. the lightweight lip on a Sprint Line wheel.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 53abea12f7d2de0cff0d8910954cbf4a59983a00-1920x1248
Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch to give us total control over the final product.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track e82967c8c0c90746d3f25fc102b9f5295a7e44a8-3840x2160
Side Milled Spokes
One of the most prominent features of our Enduro line wheels are the extra wide and deep side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. This allows our endurance wheels to be surprisingly light for their strength. Side-milling is often deemed cost-prohibitive by others, but for true performance without compromise we believe it's essential.
Weight Optimized
We conducted extensive Finite Element Analysis (FEA) to reinforce high-stress areas and to remove material where it didn’t improve strength. The result is a significantly stronger wheel with a minimal weight penalty over their RS counterparts.
We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. Our Enduro Line wheels are independently tested by ITS at their Michigan facility following JWL standards but pushed to much higher loads and much longer durations.
Whether it’s a day at the track or months of street driving, repeated hard braking and acceleration can make a tire slip along the bead seat and go out of balance, causing vibration. Knurled beads help, but are less effective when painted over. Our forged line features unpainted knurled beads that stay sharp and maximize grip.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track f838d8267bc9bc4bf58603b5097c2f0ce88f6dd5-7008x4672
Paintless Barrel
To be as light as possible, and to reduce rotational inertia, we removed paint from the outer barrel. It’s only a fraction of a pound but it’s in an area that has the biggest impact on acceleration and deceleration, so it packs a bigger punch vs. the same weight savings near the center of the wheel. These small tweaks add up.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 2f7c76596a39b4a36d66179251fb04cc58a6789d-1920x1248
Capless Hub Design
We know most track day organizations ask for center caps to be removed. To further reduce weight that doesn’t directly correlate to strength, we incorporated a capless hub design on all Enduro Line wheels in our pursuit of Real Performance.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track f8d1a88a65e4de9a24f5ea49fd539465641a8301-1920x1248
Built for Impact Sockets
Track wheels need track tools. Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All Apex wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 355545dd73e79d91af47e1f0709ab537404b8647-3768x2517
Outer Lip Pocketing
A lot of areas get extra thick when the load rating is raised to 2100 lb. By CNC machining ‘pockets’ between each spoke, our Engineers were able to further reduce weight from an area that has a high impact on rotational inertia.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track ca6f2fc065e3284fdd63f00413dafab53bcb27f9-1920x1248
As track enthusiasts ourselves, we know how frustrating it is to locate and decipher wheel specs that have been hastily marked on a wheel or become unreadable over time. Our Enduro wheels have laser-engraved specs on the barrel, in plain sight, making them easy to find and read.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 100c52a6d23cfeb47aea1bcfb7de5bce865389f3-1920x1248
APEX Flow Formed Wheels
Over the last few years, APEX has been the go-to wheel for Mustang enthusiasts looking for the perfect balance between strength, weight, and cost. Our EC-7 design addresses the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. Our newer SM-10 design provides a step-up in strength and true race wheel features like I-beam spokes and reinforced inner lip.
➡︎ Perfect fit
➡︎ Made to work with big brake kits
➡︎ 100% OEM compatibility, no extra hardware required
➡︎ Unbeatable warranty & 50% replacement program
Order Now
EC-7 / SM-10
Designs & Finishes
EC-7 - 18" / 19"
Massive brake clearance & a plethora of fitments. The curved spokes of the EC-7’s face beautifully contour around some of the largest brake calipers available. The split "Y" spokes were carefully evaluated from every aspect to ensure lightweight and remarkable strength. Available in Profile 2 (medium concavity) to provide increased caliper clearance and creating a stunningly aggressive appearance.
SM-10 - 18" / 19"
S650 Mustang Apex Forged and Flow formed Mustang Wheels | Performance Solutions for Street and Track 431759-1d3118d8f16e3d3801e689945de616f4
Modern design with reinforced lips and I-beam spokes. The SM-10 spokes were designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. Available in Profile 2 (medium concavity) for maximum brake clearance and weight savings.
Order Now
EC-7 / SM-10
Fit Matter
s
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 9cdb6296c05785ab048c4273fb3d1936ddaf3739-800x400
[CENTER}​
The right solution for every application. Our wheels include details specifically implemented to enhance the Mustang owners' track day and street performance experience. An optimized car setup begins with the right wheel and tire fitment, and without model-specific attention, maximum performance is compromised. These wheels were developed exclusively for S197 and S550 chassis, and will work in either square or staggered applications. Most fitments are direct bolt-on solutions, however certain aggressive square fitments utilizing the 11” wide wheels will require spacers on the front axle for proper inner strut clearance. This not a compromised fitment, it is the only way to outfit an S197 or S550 chassis with the highly desirable true-rotatable 11” square fitment.
Simply put, our wheels are designed for long-term durability without sacrificing performance and fit, while also adhering to APEX’s mission of maximizing value. Corner carving & track enthusiasts: this is your wheel.
100% OEM Compatibility
No need to change your wheel bolts, center caps, or TPMS sensors. All APEX Mustang wheels were designed from the start to work with OEM 60º tapered hardware, which means both OEM lug nuts and aftermarket stud kits with the proper lug nut seat type will fit perfectly. All of our 5x114.3 Mustang wheels use a 70.5mm center bore, no hubcentric rings or adapters are necessary. All wheels come with gloss black APEX center caps, but you can also snap-in select OEM Ford caps for a more OEM+ look. All APEX wheels accept OEM and aftermarket equivalent TPMS sensors, and any standard-sized metal or rubber valve stem.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 2e4932ba4bdcf15a2bb14c7b95e530ec94f34d6c-1000x640
Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 44de4c6dc0295517a37eb77dae70b5125062c47f-400x400
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Lifetime Warranty
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 96b668a36288283965b5023c692f3e0bd1930b43-1000x750
All APEX wheels come with a lifetime structural warranty against defects in workmanship and materials, plus a 1 year finish warranty. Exchanges are fast, easy, and hassle-free.
Learn more
APEX Wheel Replacement Program
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 65005bf77ff8e33a7516e129c38ed2e4b624f365-1000x750
Curb rash or pothole damage on the street? Make an oopsie at the track? We’ve all been there. APEX is proud to offer 50% off replacement wheels, no matter the damage.
Learn more
A Fitment For You
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 3187d5a5764060182731533995d685b12513ca94-6000x4000
We’ve tirelessly test-fitted hundreds of setup combinations in order to provide direct-fit, spacer-free wheel packages for everything from showroom-fresh cars to all-out race builds. Our detailed fitment guides help you avoid costly trial-and-error and walk you through every step of finding your perfect setup.
Explore Our Fitment Guides
Apex Mustang Gallery
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 71ea3dcc6f8ff0bf1595de24911a6809a0a931e0-6634x4423
Questions?
Call: 925-245-0773
Email: [email protected]
Web: www.apexraceparts.com
Are the "Sprint" wheels recommended for our Mustangs? I ask only because of the weight. These cars are not 3200 lbs. Street and/or track HPDE days only (with sticky tires and kerbs).
Apex Wheels
Apex Wheels
Gold Sponsor
Bay Area
Mustang
Apologies for the delayed followup!
Yes, the Sprint line wheels and our other 1600lb-rated wheels are recommended for the S650 chassis. While the newer cars are certainly heavier, we run GVWR and rated Axle weight calculations for all new vehicles to determine which wheels we offer for them. 1600lbs is sufficient for street and track use on new mustangs even with sticky tires.
If you do consistent HPDE days running slicks and aero or need additional strength and stiffness for wheel to wheel racing series, we also offer our VS-5RE Enduro Line wheel. These are a higher load rating wheel with additional material on both the spokes and inner lip. They are a heavier wheel, but are built for the rigors of competition use.
This was the reason that particular wheel was chosen as a homologated wheel for the Ford Mustang Dark Horse R run in IMSA Mustang challenge.
-Tom, filling in for JJ
Apex Wheels
Apex Wheels
Gold Sponsor
Bay Area
Mustang
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 7274d5ddaa6a1240bb83bb112fdd4ca9f10c5f50-2061x1080
Our crowd favorite ML-10RT is back. We’ve discounted all ML-10RTs to 10% off across the board while select fitments and finishes are discounted even more deeply, up to 25% off. With free shipping included on these wheels for the lower 48 US states, now is your chance to lock in a deep discount through February 28th.
The mesh lipped aesthetics of the ML-10RT have made it an iconic design among enthusiasts who appreciate classic styling with modern performance and features. What started as an internal skunkworks project has morphed into a wide range of chassis-specific fitments optimized for your Mustang.
We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error.
View our fitment guides.
Questions?
Call: 925-245-0773
Web: www.apexwheels.com
Hours: M-F 9a-5p PST
*Free Shipping to the lower 48 Contiguous US states
Apex Wheels
Apex Wheels
Gold Sponsor
Bay Area
Mustang
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 1d7824d12ee903fdd2f364e0915e9454d6f4eb80-1280x1656
Don't miss our biggest end-of-summer sales event! Our top Forged wheel designs are 10% off + FREE Shipping* only for a limited time.
This sale ends on Thursday, September 10th so don't miss out and get your order in today!
Buy Now
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 9770150995383bf4879dccfda49056de785053b1-2061x1080
VS-5RS: 10% off + free shipping
Forged Performance, Sprint Line Light. The VS-5RS brings our signature split 5-spoke design language to a forged, weight-optimized platform. Built for enthusiasts who want the strength of forged construction without the weight penalty, the VS-5RS delivers Real Performance to a wider range of Mustang fitments than ever before. Kick off fall with 10% off and free shipping* on every VS-5RS.
Buy Now
ML-10RT: 10% off + free shipping
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track c7ae41576e91b950837232c134ea11027bc5d849-2061x1080
Style meets substance: The ML-10RT rounds out our Forged Touring Line with a mesh design built to balance aggressive looks with everyday drivability. Modifying your car and increasing its performance shouldn't cost an arm and a leg, especially as everything gets more expensive. Save on all ML-10RTs with 10% off and finish the summer strong.
Buy Now
VS-5RE: 10% off + free shipping
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track cd5e74a551a5c2ab1d6fa9f389eca18397d02896-2061x1080
A forged design focused on strength Whether you need a robust wheel for racing applications or a higher load rating for modern performance cars, we've got you covered. The VS-5RE (Enduro Line) is our race-ready forged wheel perfect for cars with slicks and aero where strength and stiffness in a wheels design matters most. The VS-5RE (Enduro Line) brings Real Performance to heavier applications ensuring that today’s performance SUVs have an option tailored to their needs. Both are 10% off with free shipping* for Labor Day.
Buy VS-5RE
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 2e28e48551e3bfb7dd4c70c3525841eaa72cb46c-1080x1080
Apex accessories like wheel hardware and spacers are discounted by 20% across the board. In addition to that, our color-matched valve stems are discounted by 50%, ensuring that you get the perfect match to your new Apex wheels.
Fitment Guides
S650 Mustang Apex Forged and Flow Formed Mustang Wheels | Performance Solutions for Street and Track 6fc20f71e463563cff342f8f0ee4b3f0837e61a1-6000x4000
*Free Shipping on On Sale wheels to the 48 Contiguous States only.
Questions?
Call: 925-245-0773
