26C40/26V547 - Recall - Engine harness ground eyelet replacement
KFishohio
2024 Mustang EcoBoost, 2024 Edge ST Line
Hello All,
I did a quick search by the campaign number and could not find a result. I get a 'health' report sent to my e-mail monthly for my'24 650 Eco. When I reviewed the latest one this recall showed up but it does not show in my Ford app so I wanted to post here to see if anyone else received this one. Below are the details per the health report.
Recall incomplete
Recall service not available right now.
We have a remedy but parts are not available right now. We will inform you when the service is available. Or, you can contact your dealer.
Issue Date
2026-08-25
Campaign
26C40/26V547
Description
On your vehicle, it may be possible for certain engine wire harness grounds to become broken under normal use. Depending on which ground eyelet fractures, this condition may result in a loss of motive power, loss of right and or left headlamps, loss of windshield washer fluid pump function, loss of air conditioning, and/or a non-working engine cooling fan. This condition may also be accompanied by an illuminated check engine light and an audible chime.
Safety Risk
A loss of motive power while driving increases the risk of a crash. A non-working headlamps may reduce the driver's visibility and/or make the vehicle less visible to other drivers, increasing the risk of a crash. A non-working windshield washing system increases the risk of a crash.
Remedy
A remedy is not yet available. Ford is working to provide parts for this repair. When the remedy becomes available, Ford will notify you via mail to schedule a service appointment with your dealer for repairs to be completed free of charge. The remedy is anticipated to be available on December 21, 2026.
Next Steps
Contact your dealer for more information to schedule the free service.
Just did a quick Google search and found this...
The information you are looking for relates to an active Ford field action: [1]
Ford Recall Campaign 26C40 is an active manufacturer program targeting 2024–2026 Ford Mustang models equipped with 2.3L and 5.0L engines. The equivalent National Highway Traffic Safety Administration (NHTSA) campaign identification for this specific software/hardware compliance defect is tracked under NHTSA Campaign 26V547. [1, 2]
What is the issue?
The recall involves an advanced notice status regarding specific software logic or component parameters in the newest generation of Mustangs. [1]
    • Note on Ford codes: In Ford's tracking framework, a code ending with "C" (like 26C40) indicates a Compliance Recall or localized program rather than a standard Safety Recall (which usually begins with an "S"). []
    • A compliance recall means a component or module fails to satisfy specific automotive regulatory requirements or software standards, requiring an authorized manufacturer modification. [1]
Affected Models
    • 2024–2026 Ford Mustang (Specifically the 2.3L EcoBoost and 5.0L V8 powertrain variants). [1, 2]
How ironic, the non-ev version has a short.
mks
CO
2026 DH T3590
Looks like my engine harness ground eyelet need replacing, too.
