- Joined
- Oct 7, 2014
- Threads
- 33
- Messages
- 212
- Reaction score
- 105
- Location
- California
- Website
- www.modularmotorsportsracing.com
- Vehicle(s)
- Worlds Fastest & Only 5 second Coyote
- Thread starter
- #1
IN STOCK - same day shipping available
MMR has paired up with MCS to bring our Road Racers the highest quality Coil over kit on the market for the S550 (2015-2024 Mustang GT, GT350 and GT500)
In carefull consultation with MCS, MMR has put together the most reliable, best performing and best fitting kit available. The kits feature remote nitrogen reservoirs for easy adjustablity. Turn the clicker dial to adjust compression or rebound in just seconds! kits are fuilly rebuildable and serviceable.
With the MMR / MCS kit you can expect to acheive faster lap times, better tire wear and a system that will grow with you as both you and your car progress.
These double-adjustable dampers with a remote reservoirs increase compression blowoff capacity and adjustable gas pressure. Effective stroke is increased and valving options are increased.
Complete front and Rear True Coil Over kit
All Hardware
Hypercoil or Eibach Springs (select rate online)
MMR Billet rear dual position height bracket for the rear shock mount which improves adjustability and sag heights
MMR Billet Reservoir Mounting Brackets
Rubber Grommets for Trunk mount reservoirs
Factory Magnaride equipped applications (such as GT350 & GT350R) will need to select the MMR Magneride Overide Kit below (easy plug in install)
This kit requires aftermarket Camber plates specifically designed for coil overs. MMR is happy to assist you determine compatibility or you can add MMR Camber plates in the options below.
- Monotube Design
- 18 clicks of high speed compression adjustment
- 18 clicks of rebound adjustment
- 22mm strut and shock shafts
- Adjustable reservoir nitrogen pressure
All Hardware
