Diode Dynamics
St. Louis, MO
www.diodedynamics.com
2015 Mustang EcoBoost
One fog light. Two outputs. No compromises. Our new Dual-Color Elite Series and Stage Series SS3 fog lights put bright white and selective yellow light in the same kit, so you're ready for changing road and weather conditions with the push of your factory fog light switch. Built around our proven platforms, they deliver the same trusted performance with added versatility for changing conditions.
Switch colors with confidence. SmartSelect technology lets you change between white and selective yellow output using your factory fog light switch. It intelligently recognizes the difference between an intentional color change and normal vehicle operation, preventing high beam flashes and other signal interruptions from accidentally switching colors.​
The beam stays exactly where it belongs. Unlike some dual-color lighting solutions, switching between white and selective yellow doesn't change the beam pattern. You'll get the same SAE-compliant optical performance and precise light distribution no matter which output you choose.​
A signature look, day or night. Every Dual-Color Elite Series and Stage Series SS3 fog light includes our amber backlight, adding a distinctive accent whenever your parking lights are on. Whether you're driving or parked, it's the perfect finishing touch to complement your vehicle's appearance.​
Dual-Color Elite Series and Stage Series SS3 fog lights are available for 100+ vehicle-specific kits, making it easy to find the right solution for your ride. Simply use our Vehicle Finder to see every compatible option and take the guesswork out of choosing the right kit.
Already running Diode Dynamics fog lights? Dual-color versions install using the same vehicle-specific mounting hardware and wiring, making it easy to upgrade without rewiring your vehicle.​
Questions/Concerns:
Hours:
Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Forum Member Benefit: All forum members are eligible for a free US shipping code for orders. Please send us a direct message for the exclusive code and save on any new or future order.
John C.
Diode Dynamics
2024_Night_Mare
Wisconsin
2024 Ecoboost Premium
So if I order the Elite lights for my Ecoboost I'll be getting the dual color functionality?
Sig Oris
Western Maine
Diode Dynamics
Diode Dynamics
St. Louis, MO
Recently installed the Elites and overall pleased with fit and finish .
We love to hear the positive feedback! Our engineering team spent a lot of time ensuring factory-grade fit and finish. These lights provide a significant performance upgrade, offering high-intensity output to supplement your low beams with extreme width compared to the stock setup.
They go in front of my oil cooler air intake???
That is correct. We ran our kit on several test track vehicles long before release to ensure cooling levels were not impacted. We have since sold hundreds of kits to Mustang owners nationwide with performance packages, and have not experienced any issues.
Yes, when viewing our product page, you can select between white-only, yellow-only, or dual-color output. The dual-color option is clearly visible in the configuration menu during checkout.
FireShot Capture 2831 - 2024 Ford Mustang Elite Series Add-On LED Fog Light Kit_ - [www.diode...webp
@Diode Dynamics I'm considering getting this setup when I get my EcoBoost RTR. How do you switch the color from white to yellow when the Mustang does not have a fog light switch?
That's a great question! Our add-on fog light kit has the main beam turn on with the low beams. To change the color, simply turn the low beams on and off using our programming method as seen below!
GooberDH
2024 Mustang Dark Horse
I miss my yellow SS3 Pros so bad. Shame there's no place to put them on the Dark Horse.
