Elite Series Add-On Fog Light Kit | GT + EcoBoost | Diode Dynamics
Diode Dynamics
St. Louis, MO
www.diodedynamics.com
2015 Mustang EcoBoost
Introducing our new add-on Elite Series Fog Lamp Kit for the 2024 Ford Mustang! This kit allows you to mount two SAE-compliant fog lamps in the factory bumper while maintaining an OEM appearance thanks to the custom-designed, vehicle-specific bezels.
OEM+ Appearance. Our team of in-house engineers have designed two unique bezels to fit perfectly into the factory bumper of the GT and EcoBoost trim levels without any cutting or modification to the factory bumper.
These bezels retain the unique styling of the OEM grilles, providing a seamless appearance across the entire bumper. For GT owners, we've kept performance in mind, ensuring the bezel allows for adequate airflow to the cooling system. With an OEM-inspired design, this add-on fog light kit is sure to make your S650 Mustang stand out on the road.
Factory-like Operation. Unlike other basic harnesses on the market, the Add-On Fog Harness included in this kit allows the fog lights to operate automatically, just like you'd expect from the factory. By using our vehicle-specific harness, the backlight will come on with the parking lights, and the main beam will operate just as a factory fog light, turning on with the low beams and turning off with the high beams. This is much more convenient than manually flipping a switch on every time you want to use them!
Output that Outperforms. The Elite Series Fog Lamp is built around a highly-engineered single-piece PMMA lens. This optic was carefully designed using advanced optical simulation software to produce an asymmetric light pattern that is wider than any other aftermarket fog lamp on the market, with an 80-degree spread of highly intense light. Even with this extremely wide band of light, the pattern is extremely smooth throughout, with an extremely sharp cutoff to avoid glare to other drivers, including a BMW-style “color flicker” at the very edge of the pattern. Diode Dynamics engineers accomplished all this while still meeting SAE F3 fog light standards, for legal on-road use. Please check your local laws and regulations for aiming, installation, and applicability.
White or Yellow. The Elite Series Fog Lamps in this kit are available in a cool white or selective yellow output color.
The white is a 6000K color temperature, which is a true cool white output. This will perfectly match other LEDs on your vehicle, such as DRLs or running lights. The white option also offers a premium BMW-style color band at the very top of the beam pattern.
The selective yellow option is 3000K in color temperature, which is great for high contrast in inclement weather, or in providing a distinctive look on the road. The yellow lamp consists of a yellow multi-die LED emitter paired with a yellow-tinted lens, to provide unmatched output and optical efficiency, even with the intense yellow output.
Backlight Functionality. All Elite Series Fog Lamps come standard with an integrated amber accent light. This backlight feature fully illuminates the main lens with amber LEDs, intended to match other position, sidemarker, or corner lights on your vehicle. Check local laws and regulations for acceptable use.
Bolt-On Fitment. The brackets included with the lamps bolt directly to the back of the provided bezels. With built-in adjustment, the EcoBoost kit can be aimed after installation. A custom aiming tool is included with the GT kit to preset aiming prior to installation. Our add-on foglight wiring harness is included to connect the fog lights to your factory lighting functions. Click here to learn how to aim your Elite Series Foglamps: How to Aim Your Fog Lights.
NOTE: This kit is NOT compatible with the Dark Horse trim level.
In the Box:
  • Two (2) Elite Series Type A Fog Lamps
  • Two (2) Vehicle specific Fog Lamp Bezels
  • One (1) Add-On Fog Harness
  • One (1) Fog Lamp Aiming Tool (GT only)
  • Four (4) Zip ties
  • Two (2) T-taps
  • Hardware Kit
2024+ S650 Mustang GT Installation:
2024+ S650 Mustang EcoBoost Installation:
Assembled with Quality - in the USA. Elite Series Fog Lamps are assembled in the USA using OEM-grade materials, including a precision aluminum casting, UV-coated outer lens, copper-core circuit board, and multi-die automotive emitters. After being assembled by Diode Dynamics in St. Louis, Missouri, they are robotically sealed with urethane epoxy for long-lasting protection against moisture, and packaged in form-fit foam for safe transportation. No expense has been spared, from materials to assembly, right here in America.
Proven Reliability - Backed for 8 Years. Like our popular Stage Series lineup, Elite Series LED lamps have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components on your vehicle. With integrated moisture-proof vents, the lamps can “breath” with changes in temperature, maintaining a strong seal over time. And with built-in circuit protection for voltage spikes and reverse polarity, these lights will keep working for years. They are backed by an industry-leading 8-year limited warranty.
Experience. After over a decade in business, Diode Dynamics is one of the most trusted names in automotive LED lighting. We directly assemble and engineer our own products in the United States, allowing for higher quality and performance, with the newest and brightest LED technology. No matter what you're driving, we pride ourselves in offering only the best possible LED solutions. Please contact us if you'd like to discuss your lighting project!
Questions/Concerns:
Hours:
Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Forum Member Benefit: All forum members are eligible for a free US shipping code. Please send us a direct message for the exclusive code and save on any new or future order.
John C.
Diode Dynamics
Social Media Community Manager
femtosecond
Arvada, CO
2024 Ecoboost Premium
Looks great! Clearly a lot of work went into this. But $400 for something only other people will ever see. Need to think about it.
Diode Dynamics
Diode Dynamics
St. Louis, MO
The Elite Series fog lamps are a significant upgrade, offering extreme width and high-intensity lighting that supplements your low beams legally. They're not just for others on the road—they greatly enhance what you see from the driver's seat as well.
Here is an example image of our 3K selective yellow option:
kgautam28
Seattle
Aston Martin DB9, DB11, Mustang Mach E GT, Rivian R1S, Dark Horse Premium
You're not seeing the bulbs you're seeing the illuminated road Infront of you.
What do you mean only others will see
Adefend
2024 Mustang Ecoboost
In the Box:
  • Four (4) Zip ties
  • Two (2) T-taps
  • Hardware Kit
Questions/Concerns:
Hours:
Phone: 314-205-3033
John C.
Diode Dynamics
Can I get the US shipping code?
20ducks
Originally South Side Chicago
My neighbor recently had a set of white Elite-type lamps installed. What I noticed is that under the 4 positions for lamps, you get the following:
1). off....Nothing is on at all
2) Fog lamps turn on low orange/amber color. No headlamps with this switch.
3). Normal headlamps with high beam auto switched to switch to normal in oncoming traffic, etc. Fog lamps are on and at full power. No option to shut off.
4) Normal headlamps, normal illumunation with high beam control entirely up to the driver. I do believe the fogs stay on full, no matter what the normal headlamps are set at.
He also showed me the alignment tool that one uses when the kit is installed. It cannot be used once it is installed. Paradox??
Diode Dynamics
Diode Dynamics
St. Louis, MO
Yes, that’s correct on 1, 2, 3, and 4. If you want manual control of the backlight or main beam, you have to purchase a separate harness sold by our team.
As for aiming, the fog lamps in the Elite Series are designed for stock-height vehicles. The included alignment tool is only meant to be used during installation before the bumper and other components are fully bolted back on. At that point, you can access the back of the lamp and fine-tune the vertical aim to your liking.
Once the vehicle is reassembled, there’s no way to reach the adjuster — which is why you can’t use the tool afterward. That’s by design, and it’s covered in both the installation guide and our YouTube video walkthroughs.
If a shop handled the install, they may have mounted the lights and buttoned everything up without making any aiming adjustments. In that case, the lamps will sit at their default stock-height alignment.
