Think Air Filters back in stock
@MagicJMC - I have seen these before and they are very well made. You can clean them with some warm water that has a bit of simple green in it. Just dip them and swish around a bit then rinse in warm water alone, then use a shop vac on the OUTSIDE to remove most of the water then let them air dry. BTW this is the same procedure for Roush and Corsa filters (which I suspect are AFEs).
MagicJMC
Paso Robles, CA
Good to know, thanks.
